TPMS connection
scabbotts
25
9
Maine
I just installed new 19" tires and rims from TSportline yesterday. They came with the TPMS already installed but the tire
pressures are not showing up on the screen. Do you need to connect them somehow?
JAM3S
80
35
Ottawa
Whilst hoping not to sound like a jerk, did TSportline use the Bluetooth TPMS the model Y relies on that to date can only be sourced from Tesla?
glide
2,773
2,759
You need to drive on them for a bit if you haven’t done so already.
scabbotts
25
9
Maine
They say on their website that they use Tesla factory sensors. I will send them an email just wasn't sure if anybody had any experience with them.
Thanks,
JAM3S
80
35
Ottawa
Thanks,
Good luck. And as above direction seem to indicate the BT sensors should connect between 10 and 50 miles driving. But reading here often happens almost instantly.
glide
2,773
2,759
Thanks,
Yes. I have experience with them and their wheel packages. Read my post above.
DoctaM3
50
41
Pittsburgh
I bought my winter setup from TSportline & they wheel/tire combo comes with TPMS included & worked flawlessly for me. I think the OP needs to drive the car and the TPMS will read. If you are checking before you drive, the readying will be 00.
Reactions: scabbotts
Flybuddy
268
234
Fort Myers FL
Thanks,
Bought new TPMS from Tesla for my aftermarket wheels and it took about 1/4 mile of driving for all 4 to show up.
For the MY there is no other option or aftermarket TPMS yet. There are 2 different part numbers though as there is a newer version, but both are Y only. Also, point of fact, I purchased 4 TPMS from Tesla and installed on new Replika R241 rims and new tires. I flicked to the tire pressure page before exiting my garage. 2 of them showed up immediately, a 3rd came on by the end of the driveway and the 4th about 2 blocks later. Not sure why you'd disagree with a factual experience by another owner.
frankvb
729
459
San Diego, CA
For me the 4th one took more than a few miles of driving for some reason. I think the first one showed up almost immediately.
RoBoRaT
Zero Farts Given!
Nov 22, 2018
1,349
1,175
SoCalNorth
The Y autodetects....
If TSportline did not install Bluetooth Tesla OE TPMS sensors on the wheels, but instead intalled 433 MHz TPMS sensors - you should be able to have a local tire center detect them with their scanners.
If those are OE Tesla Bluetooth TPMS sensors - your Model Y should detect them.
I bet TSportline put 433 MHz sensors...
Or, I suggest "waking up" the sensors by deflating (say about 5 PSI lower) and reinflating the tires - then go drive. The Y should auto detect if they are the right sensors.
BigKRIT
75
43
Canada
Just curious how does the car know which car the sensors are on? E.g what if you pull up next to another car that also just installed sensors, and is it possible your car tires pair up with that car temporarily? Wondering how often it "resets" the connection so it's always on the right car since there isn't a pair thing going on?
RoBoRaT
Zero Farts Given!
Nov 22, 2018
1,349
1,175
SoCalNorth
Possible, but what are the odds.
I was actually thinking about testing this idea when I have spare Tesla BT TPMS at hand - don't ask me how, long story for other thread...
The car must be relying on the unique ID that each of the 4 sensors have, and it keeps it in memory to connect to them each time they get activated by the drive.
If the "ID" is not detected - the car (Model Y) auto detects new sensors. It's highly unlikely for your car to detect other car's TPMS sensor reading since those are already assigned to that (neighboring) car...with compatible frequency (Bluetooth vs 433 MHz for example)
Reactions: frankvb
Flybuddy
268
234
Fort Myers FL
Possible but highly improbable. What can happen though is that the sensors get recognized as the wrong wheel ( ie; front right instead of front left) which happened to me.
scabbotts
25
9
Maine
Thanks for the information. They did connect finally. Didn't pay attention to exactly how many miles it took but i looked yesterday and the tire pressures were indicated on the screen.
Reactions: RoBoRaT
