I mean from a hardware and protocol point of view. There is no standard OBDII ECU in there that will respond to the PIDs for speed, fuel, etc, so normal OBDII software won't find anything.
But, there are a few TPMS tools out there that claim to be able to re-program the TPMS ECU in Teslas (including roadster) and they use standard OBDII hardware. K-line is a standard protocol (ok, two standard protocols). We'll still need to drive the software, but the hardware should be simple.
Interesting. Any pointers to those tools?
I tried my OBDWiz dongle (USB) on "Auto", and it failed all the different protocols to connect with the car. (Note, I have not been able to figure out what "connect" actually means on a protocol level.) Per the logs, it tried:
- J1850 PWM, 41.6k [no data]
- J1850 VPW, 10.4k [no data]
- 9141-2, 5 baud init, 10.4k [Bus init: ...error]
- 14230-4 KWP, 5 init, 10.4k [Bus init: ...error]
- 14230-4 KWP, fast init, 10.4k [Bus init: error]
- 15765-4 CAN, 11 bit 500k 01 00: [CAN Error]
- 15765-4 CAN, 29 bit 500k 01 00: [CAN Error]
- 15765-4 CAN, 11 bit 250k 01 00: [CAN Error]
- 15765-4 CAN, 29 bit 250k 01 00: [CAN Error]
- Auto 01 00 [Searching... unable to connect]
The 4 CAN attempts, for example, appear to simply be asking for what the car supports. "01 00" is pretty basic stuff, if I understand the protocol right, yet there were no replies.
What protocol / rate did it miss?
oh, p.s.: It did report 13.6 volts, so at least I've confirmed that part working
