Yes, PM me. I'll close it up. And put it into a padded envelope.
I do not expect any issues with the addresses. I don't think the main unit even knows what the tire addresses are. It polls the antennas every 30 second or so asking them. And they need to match. That was my most recent failure was the front antenna "forgot" the tire addresses. After I reprogrammed it, it was fine again. Telsa probably would have changed me for a new unit, and the labor to put it in.
Yes, disabling the antennas just means unplugging them.
I have not tried in on my car because I don't know where the front unit is. I was able to reprogram the front by attaching my sniffer unit to the rear antenna connector. If I could easily get to the front antenna, I'd experiment on my car.
To get to the rear, there are 9 screws under the rear bumper, they are 4mm HEX bolts. Also, there are some bolts on the side near the rear tires. What you need to do is drop the bottom cover to see the antenna unit. Then you can unplug the unit. I don't even jack the car up to do so, there is generally enough room to reach under there.
The new device uses the same plug, and should plug straight in.
See this post from me:
That TPMS issue, summarized
I have parts and boards for a total of three units. I was hoping to hear from "hcsharp" about milling the boxes to fit the plugs, but he hasn't responded to the thread. My manual cutting job is pretty sloppy.
