Me again, the model S dude who posted into this thread wrongly above.
I've been reading along... and I work with electronics and would like to toss in an idea. Because this smells like EEPROM corruption and I've got some experience with that in automotive products...
I'm assuming you've tried 4 x new senders somewhere along the line, or at least tested them to rule out weak batteries there.
Just trying to be helpful, because I feel you. And this would drive me mad too.
Scott,
All excellent ideas. It is EEPROM or FLASH corruption, either from the head unit or an antenna. But the values being corrupted are addresses value being replaced with bytes that are clearly pressure and temperature values. So it's more like the system is active when it corrupts the non-volatile memory locations. These aren't pure random values.
Now that you bring this up, it was in fact exactly two months after my 2016 service that this started. After that service, my AM radio was being swamped with interference where it had never done that before. I took it back several times. They took the dash out, blaming the antenna, the antenna booster, radio grounding... except the original service never involved any of that. It was all around the PEM and power systems. AND it actually destroys radio reception on a portable, unconnected radio. So you can't blame the radio in the car, or any of it's connections. Here's what it does:
It did NOT do that before the 2016 service.
Two months later, the self destruction of the TPMS antennas began. And now repeats like clockwork.
Now, I'm sure it's not memory in the head unit, it's the actual antennas. My original post summarizing the problem shows how the antennas are polled, and how I reprogrammed the antennas and they worked fine. I never did anything with the main controller head unit. And I have to reprogram the antennas over and over...
And the antennas are powered from the head unit, they are isolated (floating) from the chassis ground. (Three wire connection: + , - , data, in a plastic case)
Also, yes all the tire senders had been replaced. In Sept 2015, a year before.
I'm equipped to do all you suggest, it's just a matter of finding time. This is a corner of my home office
