mknox
Totally agree with the above. How much work can it be to add a small section under Settings/Service showing each tire pressure with a drop-down menu next to it allowing us to assign each to a wheel location? Done!
It should be totally do-able. My previous car had a kind of clever way to do this if you wanted to do it yourself: You'd put the car in setup mode and then one of either tail light or parking light would flash. You'd go to the tire on that corner of the car and add or remove about 5 PSI, then the horn would chirp and the next light would blink. You'd repeat this until all 4 tires were set. The dealer had some sort of hand tool to make this process a lot faster, but this manual method was great for guys like me that want to do their own seasonal wheel swaps.
