Ok so I'm again looking for tpms sensors for my 2013. The guy that offered to sell his never came through, anyone else gave some they would like to sell to a poor tesla owner?
You can try here:I called around to some local shops and they quoted me $80/each. Called Tesla and they sold them to me for $50/each. Only 2 were bad but I went ahead and had them do all 4.
Let me know if you find a better deal for future reference!
Thanks. Only a $29 savings. I don't feel as bad. Good to know for next time.
I'm betting those TPMS sensors are not going to work with your vehicle.
Vehicles with VIN < 50900 use TPMS sensors from Baolong. VIN >= 50900 use TPMS sensors from Continental. They are not compatible.
The ones in the eBay listing look to be Continental-compatible ones, and with a 2013 vehicle, I'm betting your VIN is < 50900.
...Do I need to buy them...
Hey guys, I'm kinda of a noob when it comes to TPMS. Do I need to buy them when I'm about to get new tires or are they suppose to be kept from the previous tires? How does it work.
TPMS sensors are secured inside the wheels on the other end of the valve stem. They have a battery and transmit the tire pressure reading to the car so that the car can alert you if there is a low tire pressure.
TMPS sensors only need to be changed if their battery is depleted or they malfunction. They do not need to be changed along with tires.
If you get new wheels, TPMS sensors can be moved from one set of wheels to another set.
Conversely, if you want to maintain two separate sets of wheels and tires (for summer tires and winter tires, for example), you will need a second set of TPMS sensors to go inside the other wheel set. The Tesla will recognize the new TPMS sensors after a wheel change within a few miles of driving.
Tesla uses one type of TPMS sensor for VINs less than 50900 (manufactured by Baolong), and a different type of TPMS sensor for VINs 50900 and above (manufactured by Continental). If you need replacements or need a set for s 2nd set of wheels, you will need to get the correct type. In most cases, Tesla has the lowest prices on the TPMS sensors at $50 each.
Wow that was the best answer ever. Thank you so much for explaining that. I feel like I totally understand it now. !
Read your post. May be able to help. On your Tesla, do you have an icon in your settings screen to reset your TPMS? Also, if you can read the serial # on the tpms, I can program new sensors & send them to you via Canada Post.Ok so I'm again looking for tpms sensors for my 2013. The guy that offered to sell his never came through, anyone else gave some they would like to sell to a poor tesla owner?
