So, I swapped my winter tires, and put my Performance 20” wheels back on. When I left the tire store, my tire pressure was reading 42 PSI for all four tires. The next day, I was driving and saw the yellow tire pressure icon, and the tire pressure screen popped showing all tires at or right around 42, except my drivers side front tire was reading 32 PSI.
I used an old school gauge to check, and it did appear to show that it was low, so I filled up, and all was good. Next day it appeared low again so, I took it back to the tire shop to have them see if they could find anything. They submerged the tire and water, and did not find any leaks. They put the tires back on, and made sure everything was back at 42. Everything seemed to be good the next day, even showing more inflation in that tire as I drove, sometimes even 45 PSI. Then I noticed it was kind of low again.
i am going to take it back to the tire shop and have them measure it to verify what I am seeing since they did not see a leak. I also set up a Tesla service to see if there is a TPMS issue, but I wanted to see if anyone has had a similar experience.......
