Last night my wife got a notification on her phone that one of her tires was at 24 PSI on her 2021 M3LR, 5 hours AFTER she had last driven. All the others were @ 42 PSI. TeslaFi shows the car was sleeping. It was plugged in but not charging, sitting in the garage. Her tire pressures were normal when she got home per TeslaFi. She'd run over a long screw and it was leaking while sitting in the garage. Sure enough, that tire was at 24 PSI. I had to air it up to get the floor jack under it. I know you have to move the car or spin the tires to wake up the TPMS and see the pressures. I play this game with both our M3's when I try to adjust for changing seasonal temps. We had a flat on the Interstate in my car a few months ago, and this is the exact same warning, low pressure stop pull over, etc. She got the phone notification and when I went out to check it, she also had the pressure warning inside the car.
This alert is great, BUT it goes against everything I "thought" I knew about the Model 3 TPMS. She's on ver 2023.12.1. If it wasn't such a pain to get all 4 tires the same, I'd let the air out of one of my tires on my M3LR (ver 2023.6.8) just to see if I get an alert. Has anyone else seen this?
If this is a change, it's a great one. You'd know about a flat or low tire ahead of time. Which is exactly what happened.
