Now you have context:
Lol sorry guys the X forums are boring so came over here there’s more action on the 3 forums
No car that I'm aware of is faster with any sort of stability control enabled. I am aware of BMWs and Corvettes that have such modes but I've always heard that the best times are achieved by fully disabling them.Track mode is far different from traction control off. A good track mode allows you to adjust slip angles while still getting help from the computer. Few cars really let you turn off traction control, they just have an off button that does very little as the traction control often turns back on if limits are exceeded.
Track mode helps you go faster, traction control off just keeps the traction control from slowing you down.
No fuses in the 3. Computer controlled breakers instead.Probably that might add to the wear and tear under warranty, so yes, you most likely have to pay for it. In S and X, though, you could achieve same with removing traction control fuse.
I'll bet you it's higher than 90%That totally depends how good the driver is and how good the track mode is. 90% of drivers are better with full stability control on. Every year the computers get better, driver's get worse.
They could probably make autopilot faster than 90% of drivers. Haha.That totally depends how good the driver is and how good the track mode is. 90% of drivers are better with full stability control on. Every year the computers get better, driver's get worse.
Yep everything is computer controlled these days. The BMW M3 has a limited slip differential with an electric motor in it. Is that stability control? I guess I'm defining stability control as a system that adjusts throttle and braking to individual wheels to rotate the car.D has two motors and only one accelerator pedal. It also has 4 wheels and only one brake pedal.
Having just one accelerator pedal there has to be some one deciding what motor will output how much power depending on you pressing the pedal.
And there also has to be some one deciding the pressure in each brake when you press the pedal.
Really disabling all SW control would demand installing 4 brake pedals and 4 accelerator pedals. Think about what you really wish...
No. That's not a software mode. That's a vehicle hardware configuration change.Track Mode needs the option to remove the side mirrors and replace them with camera's.
I'm referring to stability control. It would make sense for them to develop traction control in house since it's much simpler and they obviously have unique requirements. Stability control uses the brake system which I doubt they developed in house.Tesla said this traction control is the first they developed, so they are not relying on a supplier.
We really don't know what happened with the ABS issue. I think it might have been some sort of unanticipated interaction between the ABS controller and the regenerative braking. Pure speculation though. They also could have screwed up the calibration/configuration of their supplier's software.Considering they wrote the ABS software I suspect they do the stability control as well... Tesla really doesn't like to buy/license software from others.
This article is missing two critical pieces of information. What track and what record?Whatever Track Mode is: Mountain Pass Performance has apparently hacked a Model 3 RWD to approximate it:
Mountain Pass Performance Unlocks Tesla Model 3 “Track Mode,” Shatters Track Record
Mountain Pass Performance Unlocks Tesla Model 3 "Track Mode," Shatters Track Record — #CleanTechnica Exclusive | CleanTechnica
Video of RWD drifting
Mountain Pass Performance on Instagram: “Did a bunch of development on our traction/stability control defeat system. I guess you could say it was a success. What do you think…”
Very impressive work though. Hopefully they'll be at the next ReFuel event and destroy the production EV record. I'd worry that whatever they're doing to disable VDC could be removed by a software update later.
