mcbarnet007
are you showing cords for both front and rear tire?
Is camber adjustable for both and front or just front?
Just the fronts.are you showing cords for both front and rear tire?
Holy crap those tires wore fast. Maybe just need some negative camber?
I’ve heard the Michelin PSS wear fast on the track. I have them on my daily driver, but never tracked it. 4S may be similar. However I love the PC2s and have found them to wear very well.
I think all-season tires would be even worse for handling heat (and of course much slower!). The fact is that autocross and track use is going to eat through tires on a 4000lb car. If the outside edge wears you can have the tires flipped to get more life out of them. Bridgestone RE-71R or BFG Rival S are the tires to have in autocross these days. I'd think about getting 9.5" width rims and 265 width tires.I'm rolling the dice (regarding fitting properly on with the upgraded brakes) hoping this will make a nice second set:
If they arrive soon, I have some time to decide what to replace on the 20s. If not, it becomes more urgent.
- TST.1885.1885.MB.M3.DWS06.PPU
- 18
I've been using all seasons (Michelin A/S 3+) on the S (daily, autocross, and lapping) as a compromise for bad weather and slower wear. In the past I really enjoyed Michelin Pilot Super Sports but I was burning through them too quick for comfort/budget.
I think higher tire pressure would have helped with the uneven tire wear. It would keep the tire from rolling over onto the sidewalls when cornering.
It's not adjustable. I bet someone will come out with adjustable upper arms.The problem is the tires get really hot, and you don't want too much pressure or else you lose grip. It looks like he just needs more negative camber, I saw someone's alignment and factory is like -.5 on the fronts. I don't know if it's adjustable, but lowering it would help.
Clarification:
Are you agreeing with my suspicion in the last bullet or saying something different? Just want to make sure I'm understanding. Thanks.
You'll be fine with stock on HPDE. I did my HPDEs in 2013 and 2014 with Model S (stock).Brian, just making sure, you completed the HPDE in your P3+ on stock brakes, stock fluid, and stock 20" PS 4S tires?
P.S. I have a HPDE scheduled in two weeks. As I don't have the whole winter tire thing worked out it might be nice to kill off these summer tires.
Haven't chased this down yet. It's on my radar though.Does anyone know which track brake pads are compatible with performance 3 with upgraded package?
Update:
Beatrice's (M3P w/PUO) front left pad is "done" (scraping metal sound) after 4.5 track days. Right front and rears seem ok still. Skipped 6th day at track, drove home w/focused attention on using mostly regen.
The navigation system is different, it doesn't use a fixed Kw/mile for the remaining range at destination. it predicts the remaining range by a number of factors. Here is a snippet from the Model 3 manual:
So they say that weather is even included in that calculation.
I think MPP already has them.It's not adjustable. I bet someone will come out with adjustable upper arms.
