Tracking car while on a transporter
Discussion in 'Model S' started by alevek, Jan 1, 2018.
Tags:
  1. alevek
    alevek Member
    Jupiter, Fl
    Has anyone tracked the car while it's being transported? Put the Model S on car transporter this morning, but location still shows the pickup point and doesn't update to current transporter location.
  2. davecolene0606
    Fort Pierce, FL
    You should be able to see it no sweat provided the cell signal and GPS signals are not being blocked by being inside a transporter trailer made of materials sufficient to block said signals.
  3. BerTX
    BerTX Supporting Member
    Texas/Washington
    It depends on the transport trailer. If it is enclosed, or a multi-level trailer and there are cars above it, then the GPS signal could be blocked. The antenna pretty much needs line-of-sight clear to multiple satellites, so quite possible to lose the signal.
  4. alevek
    alevek Member
    Jupiter, Fl
    #4 alevek, Jan 1, 2018
    That's what I thought. It's on an open transporter. Maybe there is something wrong with the app accessing the server. It now says "Updated 18 minutes ago", but the location is still where it was an hour ago and the transporter is long gone. For now it's the only car on top deck at the very end of the trailer.
  5. alevek
    alevek Member
    Jupiter, Fl
    Is it possible that there was a software change that doesn't update the car's location unless it's moving on its own, i.e. the wheels have to be turning?
  6. davecolene0606
    Fort Pierce, FL
    Not aware of any software change like that. Were your display settings on "always connected"? Any idea of the material the top of the trailer was made out of?
    Keep pinging it, best of luck!
  7. alevek
    alevek Member
    Jupiter, Fl
    Yes, it's set to "Always connected" and the trailer is open. Since the car will have to be moved to the front of the trailer at the next pickup location we'll see if that makes it updated its location. If that's the case, that would mean that a car could be stolen and non-trackable by putting it on a trailer.
  8. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    If the car is in normal mode it should work. When coming from the factory, there’s a special service mode of course.
    We assume no one from Tesla is involved here and turned off remote access, put the car in service mode, etc? If not, weird.
  9. ChadS
    ChadS Petroleum is for sissies
    Ours was just on a trailer (my wife hit something in the road and damaged two tires) and we saw the same behavior- we could connect to the car, but it said it was at the pick-up point for the duration of the trip. It updated once it arrived at the service center and was driven off the truck.
    We have seen the same thing on a ferry too. GPS location must only update while the car is under its own power. Perhaps an energy saving feature.
  10. alevek
    alevek Member
    Jupiter, Fl
    Thanks, good to know. I think most people are not aware of this behavior and assume the car could be tracked on a trailer.
  11. Rik59
    Rik59 Member
    Ottawa
    You won’t be able to track it if it’s in a container headed to Yougotrobbedistan.
  12. Snerruc
    Snerruc Member
    Palm Bay
    When mine was shipped from Hawaii to here, my car correctly reported its position when it had a cell/GPS signal and was not enclosed in ship/truck. Always connected was not checked, but rarely took more than a minute to connect. When inside a trailer, it couldn’t get a GPS signal unless the trailer door was open. It could get a cell signal. Shipper said normal for cars that can report location when queried. Car did not have to be under power.
  13. bandido
    bandido Member
    Phoenix, AZ
    #13 bandido, Jan 1, 2018
    I was able to track my car in real time using the Remote S app. My car was shipped across country and I could see it cruising along the interstate. This was in April of 2017, but I doubt the firmware has limited the function. Good luck, you can be too obsessive and check it too much, LOL...
  14. alevek
    alevek Member
    Jupiter, Fl
    Interesting, when was that?
  15. ChadS
    Assuming (?) there hasn't been a firmware change, it could depend on energy settings.
    I have energy saving on, but with the "stay connected" feature selected. I am not sure if Range Mode was on.
  16. alevek
    alevek Member
    Jupiter, Fl
    I didn't have energy saving on, but that brings up a thought. Maybe a firmware change was made to save energy, assuming that if the car is not on it can't move, therefore could save some energy by not updating GPS position.
  17. alevek
    alevek Member
    Jupiter, Fl
    Can sort of track it, interior temperature now shows 19 F. So it does look like the GPS location is only updated if the car is on, while everything else updates normally.
  18. Snerruc
    Snerruc Member
    Palm Bay
    Left Kona Sept 19 got to Palm Bay Oct 19. Matson and Coastal Auto.
  19. bandido
    bandido Member
    Phoenix, AZ
    That is what happened with my car when I used the Tesla app. I could get temp, but it kept showing the old location. The "Remote S" App let me real time track the car. Good luck!!
  20. alevek
    alevek Member
    Jupiter, Fl
    Looks like that's what happened, firmware change now only updates GPS location when car is on. Car was moved to front of trailer and GPS location updated to a truck stop in Atlanta.
