Traction control problems with latest update?
Discussion in 'Model S: Driving Dynamics' started by sorka, Apr 28, 2016.
  1. sorka
    sorka Well-Known Member
    Merced, CA
    Went out to lunch with some co-workers and tried two Ludicrous launches. Both failed as the traction control light was on constantly all the way up to 50 MPH and I didn't break 250 kW instead of the 430 kW I would have normally hit with an 81% SOC.
    Is anyone else seeing traction control issues with todays update on their PDL?
  2. bhzmark
    bhzmark Supporting Member
    Is that 430kW number the best you've seen? others are reporting 455 with recent builds. Wondering if early p85ds are limited with 430 with only later ones getting 455.
  3. AWDtsla
    AWDtsla Active Member
    NE
    traction/stability control functionality seems to be "in flux", and I put it like that because the trend isn't a slow improvement.
  4. sorka
    Merced, CA
    The best I've seen is 456KW at 91% with max battery ready. 80% is less.
  5. bhzmark
    on an early build p85d with ludi?
  6. sorka
    Merced, CA
    Mine was was built March 2015. Upgraded to L December 2015.
  7. sorka
    Merced, CA
    Nobody is reporting 455KW at 80%. In fact, I think I have the highest reported KW reading of any upgraded P85DL to date at 456KW at 91% with max battery ready.
