i just looked at the chart that I typically use on Stockcharts, and the Log scale box is checked. I haven't paid attention to that but I think it defaults to that. My upper channel line is similar to what you showed. TSLA is just below it. I wonder if most traders use Log scale?@Navin and others re longterm Downtrend Line break:
Curious, I saw on many charts that it broke the downtrend, but I did see one chart where it didn't. So I went to tradeview and drew the lines myself. Turns out on the normal scale, it broke; but on the log scale, it hadn't (just touched the top). See pics attached. So, hmm...
I actually expected it to climb higher Wed, but we can write it off to 4th of July mischief. The test will be next week. But seems like the analysts and media are pushing the narrative that earnings will be bad and this is a fade into earnings. Being a news vacuum from now until earnings, the stock may in fact fade. I don't have a strong opinion here. I think it could go either way, but I'm leaning slightly toward it going down into earnings, and then going up afterwards. Not going to trade it either way, but I will add shares if it goes lower.
(Bear in mind that if it does in fact fade, it can still stay above the channel/downtrend line (on the normal scale), if it fades slowly enough -- see chart/pics.)
View attachment 426421 View attachment 426422
I noticed that Papafox's chart also is on log scale, and he also pointed out that TSLA is at the top of the channel.i just looked at the chart that I typically use on Stockcharts, and the Log scale box is checked. I haven't paid attention to that but I think it defaults to that. My upper channel line is similar to what you showed. TSLA is just below it. I wonder if most traders use Log scale?
It is not the time duration, but the price difference that determines use of log scale. But yes, generally, over long durations stocks tend to go up significantly. So there is a correlation. But if some exceptionally bad stocks stay flat over long durations, log scale is pointless.I'd only bother with log scale on very long time durations.
Do you own common stock as well? I would own some Tesla with your gains. It’s too low not to.I’ve had a good past month, my luck is bound to run out soon. Not using any options. Just trading lithium stocks and shorting macros on a day to day decision basis. TSLA was probably half of it or so. This is only play money for me around 1 months salary. Thinking I should probably cash out gains once whenever I’m up a fair amount (like now?) and always keep it near 1 months salary so it stays a game. I think I’ll make better decisions that way and just keep it as fun. And I probably should just continue staying away from options.
TSLA seems primed for another leg up into earnings.
