Wiki Trailer-friendly Supercharger Locations
Thread Summary
Member Generated Post Wiki
Aug 14, 2012
38
  • | This is a WikiPost. Members with appropriate permissions may edit.
Note that the links should take you to threads on TMC that include photos of the layout. Use your own judgement as to whether these locations are viable. Obviously no guarantees that they'll work, so if you have trouble please come back and edit the wiki for others.
Category 1: Unhitching not necessary
---United States---
Bakersfield
Stall on far left (as you face the row of pedestals) is a pull in, and that area of the parking lot has multiple entrances and a lot of space; if your trailer is less than around 24 ft you won’t inconvenience anyone when charging at that stall and not unhitching.​
Fairfield
One stall is off by itself, if parking lot is not crowded could charge there and while trailer would be blocking a parking lane it would be easy to drive around it.​
Fountain Valley
One possible location which might block a couple of ICE/flex spots.​
Hawthorne
Pull through spots but a very tight parking lot with lots of SpaceX and Tesla traffic. Not recommended but possible.​
Mammoth Mountain
Back to back stalls may require parking on the outside and pulling the cable through.​
Manteca
Pull through spots in a mall parking lot. Trailer would be an annoyance in the lot, but the spots are far from shopping so it's possible. Note also that the spacing on the obelisks seems tighter than in other pull-through locations.​
Petaluma
Back-to-back pull-through chargers. If you park in the spots on the north side of the chargers, you could take one of the Supercharger cables and still not block the second space. It is also possible to only block one stall while charging from the forward stall.​
Rocklin
Pull through stalls, may allow outside cable or by blocking a single charger.​
Tejon Ranch
Plenty of space behind any of the chargers for vehicles to maneuver.​
Colorado
Brush
One pull-in spot
Idaho Springs
One pull-in spot
Lakewood
One pull-in spot
Loveland
One pull-in spot
Thornton
One pull-in spot
Trinidad
One end pull-through spot has plenty of clearance behind it for a trailer.
Idaho
Twin Falls
Appears to be a single pull through charger that would work.
Illinois
Mount Vernon
End charger is pull-in. This location is not ideal for trailers as the charging bank is a dead end with ICE parking opposite the charger row. Plenty of parking lots to unhook in nearby lots. Stop on the north-south road and survey the scene to decide.​
Indiana
Indianapolis
End charger is pull-in and the charger is in a hotel lot.​
Kentucky
London
End charger is pull-in and it's in a visitor center parking lot.​
Kuttawa
End charger is pull-in and it's adjacent to a hotel parking lot.​
Maine
Augusta
1 pull-in spot. You'd be blocking an end of an aisle, but it's (currently) in a little-used area and it would easy to get round the other way. Other notes in post below.
Supercharger - Portland Maine
1 drive thru stall. 1 nose-in stall​
Montana
Butte
The end charger has a vacant space next to it that appears to be workable.​
Nebraska
Ogallala
You can park along the back of all 8 chargers.
New Mexico
Santa Rosa
Pull through chargers, two look doable, and in the linked photo someone has a trailer, so it's definitely possible.​
Ohio
Cincinnati (Blue Ash)
End charger is pull-through. Trailer would have to be short and angled in order to avoid blocking the roadway.​
Oklahoma
Oklahoma City
Charger on the end works pretty well and has some room to back and angle trailer a bit.
Oregon
Sandy
There appears to be a single charger at this location that is usable by an MX hauling a trailer. The remainder are back-in.​
Springfield
Stall 5A is pull in. It is in a large parking lot where even though your trailer will block some parking spaces it is unlikely to be a problem for anyone, and it won’t block access to any other charging stalls. You will need to enter the parking lot from Hutton St. The 14 stalls there are back-to-back in two different parking lots.​
Tennessee
Manchester
Stall 1A is pull-in. You will block one to two stalls with your trailer, but 4 - 5 stalls should still be accessible.
Texas
Denton
At least the far left can be used (though it blocks some distant parking spots).​
Washington
Ellensburg
One charger that would marginally, but not completely block the lane.​
Vancouver
There is one pull in stall which could be used without unhitching only if most of the other 12 stalls are not in use, as even a short trailer will block at least 3 other stalls.​
---Norway---
Nes i Ådal
Room for 4 cars with trailer without blocking access to remaining chargers. Additional photo.
Category 2: Unhitching Necessary
Category 3: Trailer will block charger(s)
Arizona
Buckeye
Stall on far left is unusable because of the drive through entrance. Trailers around 20ft will block the next stall but not traffic. Plenty of room to unhitch.​
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
I thought it might be worthwhile to create a thread with a wiki to keep track of Supercharger locations where at least one charger is in a trailer-friendly location. I believe there are three categories.
Category 1 - No disconnect necessary
  • Charging cable can be plugged in without disconnecting trailer (e.g. pull-through spots)
  • Charging with the trailer does not block through-traffic
Category 2 - Disconnect necessary, but space is readily available for trailer parking during normal business hours. I'm not sure it's worth listing these, so I'll leave them out for now. But I do think it's valuable information to at least know the inverse.
Category 3 - No disconnect necessary, but will need to block one Supercharger stall. The idea here is that you could pull parallel to a bank of back-in chargers from the left. Using the charger on the far left, the front of the MX would block the second charger over. This requires space to the left of the back-in Supercharger bank.
Please edit the wiki below and add any that you think qualify.
Reactions: Rossy
Half Dollar Bill
Traveller, teacher, poet, accountant, innkeeper
Oct 19, 2013
1,669
2,181
Freeport Maine
I tried to go through my travel pix for verification. Ultimately some of these will be owner judgment calls about whether to unhook. Please feel free to edit/substitute my commentary.
Indianapolis, IN - end charger is pull-in and the charger is in a hotel lot.
Manteca, CA - All spots are pull-in and it's a mall parking lot.
Hawthorne, CA - From my recollection, getting to the spots and maneuvering with a trailer could be challenging.
Blus Ash (Cincinnati), OH - I believe the end charger is pull-in but the chargers are right by the service bays.
London, KY - The end charger is pull-in and it's a visitor center parking lot.
Strasburg, VA - All chargers are pull-in but it's a busy restaurant lot.
ItsNotAboutTheMoney
10,228
7,322
Maine
Augusta, ME:
- 1 pull-in spot. You'd be blocking an end of an aisle, but it's (currently) in a little-used area and it would easy to get round the other way
- Other end of the 2 x 4 layout would allow for the possibility of pulling in at an angle to charge, although it would block another spot.
- There are double-spots next to the Supercharger stalls, and it's in a little-used area, so if you do need to detach a trailer you'd probably be able to do it quite conveniently.
The first person to charge there had a good photo showing the layout: Supercharger - Augusta ME - Page 7
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
I've added a potential third category, based on my review of photos of installations around the country. I think there are too few "Category 1" chargers. I think the third category is a little selfish, but only if the Supercharger is busy. If not, there seems to be little reason to worry about it. One downside is you're likely to be there longer because you're going to need more range to reach the next charger. Any thoughts?
cpa
3,005
3,708
Central Valley
Ohmman,
I have used Manteca about a dozen times the past year. Doubtless you have used it too, since you are in the Marin/Sonoma County region. Manteca is a little tricky to maneuver into unless you approach the pedestals from a parking aisle.
From my experience Manteca does not seem to be too crowded with Teslas until late afternoon. Daytime parking with ICE cars in the general parking lot is virtually nil. However, I have charged Friday and Saturday nights (~6:30 - 8:30) and the general parking lot is full with people eating out and/or going to the movies. Date night and all that. Those times are also higher Tesla usage times--I had to share a paired stall two out of the four times that I charged during those days and hours.
So, I would think that there would be those times at Manteca when the ICE lot is full and there are several Teslas already plugged in. Trailers might very well block ingress and egress not only for Model S owners but also for ICE drivers who are cruising the parking lot looking for an open spot.
I think the last thing we wish to do is to upset the 99.99% of automobile drivers by blocking easy maneuverability in a tightly-configured parking lot during heavy usage.
One final note is that backing up safely with a trailer on a swivel hitch is not an easy thing to do. It is worse if the vehicle is slightly angled into the parking stall, and not perpendicular to the aisle. I do not doubt your ability or the ability of many drivers out there. But we all know that a lot of folks are inept when it comes to this skill. The tight aisle that accesses the supercharger pedestals makes the task even more daunting.
Good luck in your pursuit, and I certainly hope that there will be an easier solution down the road so that all you Model X types that wish to tow a trailer will have an easier time getting into and out of the Supercharger stalls.
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
Thanks, cpa.
I think your note is an important one, which is why I mentioned that judgement is important at the top of the wiki. I've been to Manteca at 7am before, and I could very easily (and without annoying anyone) get a vehicle with a trailer in and out for charging. There are times of day it would be completely impossible, though.
The comment about backing out with a swivel hitch is a great point as well. That's one reason the back-in Superchargers with a single pull-through on the curb are ideal, if you're able to do so without blocking the way.
In the end, I think most of us will be stuck unhitching for charging. It'll certainly be a pretty big drawback if medium distance camper travel is the goal.
Half Dollar Bill
Oct 19, 2013
1,669
2,181
Freeport Maine
This might be a Category 2?
I just saw a picture of Newburgh NY yesterday and it reminded me that the spots are pull-in. The charger is at a restaurant, however, and maneuvering is tight during business hours; it would be even tighter with a trailer so I think unhitching would be advised. There is plenty of parking for the trailer around the establishment.
Half Dollar Bill
Oct 19, 2013
1,669
2,181
Freeport Maine
Just got to Tannersville PA and noticed that there are two pull-in chargers here as well, 1A and 4A. The chargers are around the back of the building in a less used spot so you may not have to disconnect but it would be a tight turn around so you may want to after all.
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
FYI, I contacted the Supercharger team about the desire for some trailer-friendly locations and received the following response:
Thank you for your email and feedback. Though there are many factors which can influence the site layout, we do strive to design stations that allow for a variety of mobility.
We certainly appreciate your suggestion and we will keep trailers in mind when designing future sites. Keep checking our website for new site announcements; we appreciate your enthusiasm and support in Tesla and our Supercharger technology.
Thank you,
The Tesla Supercharger Team
steve56
TeslaTouring.com
Nov 27, 2013
15
20
Thanks for creating this thread! I have a Model X with the towing packing. I am making a trip from Southern California to Missouri and have a lot of stuff I'd like to bring with me to drop off in Missouri. I was giving some thought to renting a trailer, but the list provided here has helped make my final decision to not do so. I really don't want to unhitch and re-hitch at almost every Supercharger along the way. Instead I'll just stuff the Model X with as much as I can and worry about how to get the rest to Missouri later. I made this same round-trip about a year ago in my Model S but had no reason to make note of which Superchargers are trailer friendly. As I make this upcoming trip I will make notes at each Supercharger based on the categories you listed and take photos to try to show the layout as relevant to charging with a trailer. This trip, just like the one I did a year ago, will pretty much take me straight north on I-15 and then straight east on I-70 all the way to St. Louis.
I purchased my first Model S in early 2013 (since replaced with a 2015 Model S P85D). There were very few Superchargers around at that time. I still have my Roadster adapter cable as there were more Roadster charging locations than Superchargers at that time. The first Superchargers were mostly the type where you drive forward into them. In that configuration it made sense that the Tesla would have the charge port in the rear. But for some reason Tesla changed to a configuration where you have to back into most Superchargers. I assume those turned out to be easier, quicker and less expensive to build. With that change, maybe Tesla should have started building with a charge port in the front or maybe both front and back. This would certainly have made a lot more Supercharging locations to be trailer friendly. Any word if Tesla is at least going to come up with an extension cord so that any Tesla can just pull in forward, but especially one pulling a trailer?
Reactions: Rossy
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
Thanks for checking out the sites and contributing. I agree, it seems like too much of a pain to pull a trailer right now.
Have you considered an open hitch-mounted cargo tray, something like this? 500 lb capacity and you could use tie-downs to keep things in place. I don't think you'd get a huge hit on range and I do think you'd fit at Superchargers. Might be worth a look.
steve56
TeslaTouring.com
Nov 27, 2013
15
20
Thanks for the suggestion. I looked at it, but I'm not sure that will work for me. Everything I'm taking is in banker boxes. That tray looks like it could maybe hold 3 banker boxes, or maybe 6 if I stack a second row. And of course, if there is any inclement weather it will destroy the banker boxes. I'll have to give it some thought and see if there is some kind of enclosed weather proof box I can put in the tray and transfer the materials from the banker boxes. But definitely thanks for the suggestion! I'll explore and see if something like that might help out.
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
You might also find one of these useful. Good luck with the trip and keep us posted!
