I've had the Service Center install a factory hitch on my X. While towing a small utility trailer, my panel indicator shows a yellow trailer icon. In the manual it shows the icon as blue. What does the yellow rather than blue indicate?
Page 75 of the Model X manual available atI've had the Service Center install a factory hitch on my X. While towing a small utility trailer, my panel indicator shows a yellow trailer icon. In the manual it shows the icon as blue. What does the yellow rather than blue indicate?
Sorry Jim, but that is not correct. See above.Yellow indicates that the Tesla recognizes that it is towing something. The blue icon is lit when it is not towing something.
Oops, my bad. I have been disabling trailer mode by turning it off because I have a permanently connected trailer plug (thus getting the yellow icon), and realized that the blue is the connected mode. We even have a little chant before pulling our trailer: "Blue (for the trailer icon), and .C. (for the brake controller.)Sorry Jim, but that is not correct. See above.
Glad you got the info, despite my misinformation. JimThanks for the owner's manual reference. That's all I needed.
So sorry for the misinformation! Jim
It is the converter. Since we converted to the draw-tite hitch assembly it is easier for us to simply leave the converter attached under the pan for use when we travel (as in next Sunday for two weeks!). Thanks for pointing out the distinction. JimA full and active plug? Or a converter? I have a 4 to 7 adapter that I leave plugged in. My car won’t kick on the blue icon until I plug the flat 4 in.
It’s a simple one, no testing lights or anything.
I think that Tesla will not offer such an extension cable. It would introduce greater resistance into the charging system (greater overall length and an additional connection junction) and an additional failure point. I just don’t see why Tesla would feel it was worthwhile to put resources into designing, manufacturing, and selling such a product that would have a very limited market.
One day we might see a Tesla to J1772 adapter though to allow other electric vehicles to charge on the Tesla network. Then wouldn’t you be able to use that with the UMC as an extension cord?
Nope. Superchargers deliver roughly 400V DC at 300 amps (120 kw). J1772 are for low current AC only applications only, 208/240 VAC at 30 amps maximum.
What you *might* see someday is SOB (some other brand) EVs with an adapter for the Tesla connector to whatever DC connector is installed on the SOB EV. However some of the upcoming EVs seem to be moving to an 800V battery, which would seem to limit the charging options even further.
At the very least, interesting changes are coming someday, probably not soon.
80 amps maximum. SAE J1772 - WikipediaJ1772 are for low current AC only applications only, 208/240 VAC at 30 amps maximum.
This issue has been discussed before. SeeTesla should consider a couple drive through stations at each location.
They could use signage similar to the "use last" signs on the handicapped charging stalls.
Sure make things easiers for people towing trailers.
