In fact I've never heard of any lithium battery EV catching fire during or soon after an accident, all fires that I'm aware of other than the crash tested Volt were from parked vehicles that were plugged in and charging. I don't know how many LEAF's and iMiev's have been crashed but there must be a good number by now.
It seems as if the battery coolant may be flammable as well, depending on what is used, so that may need to be drained.I think Nikki is spreading incorrect information again, regarding "draining" the battery after an accident by puncturing it. They have to be talking about discharging the pack, not the electrolyte, since the battery is made up of many individual cells and you could not drain each individual cell without completely disassembling the pack. There may be liquid electrolyte, not much though, but it is flammable. However it is not necessarily toxic, some electrolyte you can actually drink, not that I'd recommend it.
...The battery cooling technology, which is new to the automotive market, prevents the Volt's lithium-ion battery from overheating by enabling efficient heat transfer between the battery pack's 200-plus cells. This occurs as battery coolant circulates around individual plates located between the cells...
...The battery cooling system circulates a pre-mixed DEX-COOL® which is a 50/50 mixture of DEX-COOL® and de-ionized water...
...That Volt caught fire because NHTSA did not know to drain the Volt's battery. The battery case had been punctured, spilling coolant, which caused a short that in turn triggered a fire, GM spokesman Rob Peterson said Monday.
The automaker is working to give NHTSA its tool to drain Volt batteries, Peterson said. The tool should be available at dealerships next year, eliminating the need for the GM team to visit in the case of a crash.
GM has had to send out employees to drain batteries only a few times this year, he said, since the automaker has sold only about 5,300 Volts so far...
Don't confuse coolant with refrigerant. CO2 can be used as a refrigerant. In temperate climates, Tesla could probably get away with mostly water for coolant, though the antifreeze typically also helps keep the water pump lubricated among other things.I'd like to see CO2 as coolant agent in car HVAC. Must redesign to accommodate for higher pressure, though.
I am not sure if it is feasible to run pressure-proof tubing through the pack.
Does Tesla use the coolant loops to heat the pack, too? That wouldn't be feasible with CO2, methinks.
Thanks Doug, coolant and refrigerant surely do different jobs here. CO2 is used in heat pipes, will that work to cool the pack?
JRP3, I assume the "different mechanism" to heat the pack is implemented sending electric current through the cells. Do you mean the coolant agent is heated then circulated through the pack?
