I had a new set of tires installed earlier today at Costco. After driving it for a bit, I noticed that the the pressure of the driver-side rear tire was only 34psi. I went back to Costco and had them check that tire. They used their tire inflator (set at 42psi) on it and the inflator beeped (set pressure reached) right away, They said it'd take some more driver to have the monitor reset. Since I had bought some frozen food while I was there, I decided to drive home first.
After coming home, I used my own pocket tire pressure reader to check all the tires. Surprisingly, the tire that's low is actually the passenger-side front tire!
My questions:
1. What could be causing this transposition of pressure readings?
2. Do I have to bring the car back to Costco to get this fixed, or can I use the TPMS reset to get this corrected?
Thanks!
My questions:
Thanks!
