Traveling for 2 weeks, no charging
Hey all,
I’ll be visiting family abroad for next 2 weeks, and my X will stay inside my parking garage.
We don’t have a charging installation yet, so the car will be parked without being charged. To make things worse, our garage has no WiFi or LTE access.
What’s the best use case here? Should I charge it to 100% and hope for the best? Should I charge it to 50%? Enable range mode? Disable mobile access?
Help?
Thanks!
I am currently away for about 2 weeks. I left my car at about 86%. I checked the app today, 1 week later because I got the software update notification and my charge was at 80%. I believe that the car takes up about 1% of charge daily for general maintenance. So you should be fine for 2 weeks. You will prob lose about 15%.
Don't charge to 100%
We left car for just over a week. Didnt loose much. Charge to 80% or 90% or even less. You won't loose much in two weeks. Not something to worry about. Like someone else mentioned you can plug it into regular outlet. Not necessary though. I would worry more if it was left outside in the sun or winter.
The 'do not charge to 100%' is highly overrated imho. My 5 year old (220k km) Model S has been charged to 100% many, many times. No noticeable difference in degradation. The vampire drains starts to bleed off the back after charging has finished.
Now, 90% is just fine, but you don't have to nanny the battery. For two weeks a 90% is probably just fine, but 100% wouldn't instantly kill the battery.
No one is suggesting that charging to 100% would kill the battery, or that charging to 100% many times when you need to is a problem, assuming you’re charging to 100% to drive somewhere. But there is no reason to charge to 100% to let the car sit for two weeks.
Reactions: Fiver and Rocky_H
The 85 Battery is awesome. I have a gen. 1 90 battery - not so much.
Fair enough :) Text can sometimes loose the context.
If the OP charges to 90% the car will be just fine.
is there any access to 120V even with an extension cord? That works wonders for us. Then you could leave the SOC in the middle as recommended by most. The car would use the 120 as needed for keeping the 12V battery charged and any BMS draw for heat control and cabin heat protection.
Hey all,
Help?
Thanks!
Charge to 90%. Turn on "Energy Saving." Turn off "Always Connected."
In this configuration my X only loses 1.2% per day. I just completed a 2 week trip and the car had plenty of charge on my return.
Reactions: GSP and xyeahtony
I wish. No outlet around, trying to convince our apartment building to let me install anything close to the car.
Interesting. I don’t remember having those options in my car. Where can I find them?
Thanks!
Best practices,
Charge it to 80, after 24 hours it will enter deep sleep mode, choosing about 3-5 rated miles per day, and don't check it very often with the mobile app as it wakes the car up out of deep sleep mode and will consume anywhere from 9 to 14 rated miles per day.
Don't worry, your car will be fine. I parked in a Las Vegas hotel garage for five days straight checking the mobile app only every other day (3 times) and consumed about 30-35 rated miles. Plenty remained to return to the Supercharger 40 mile away.
Charging to 100% then driving the vehicle right away is not that bad because the cells are not held at a high voltage. That's very different than charging to 100% and letting it sit for a week. That's just plain bad advice -- at least according to the science:
I'm sure your Model S battery is fine, but he asked about best practices. So to give him a bad one, then say the best practice advice is "overrated" doesn't really answer his question. And that's aside from the fact that I don't agree it's overrated advice. My 2012 Leaf that we have set to charge to 80%, and only charge to 100% when needed and we drive right away, has only lost one bar in 6 years of daily driving with a much smaller battery pack and no thermal cooling. My early 2014 S has only lost 4%, the majority of which went in the first 6 months.
