just got my model 3. June build. There is tremendous road noise with any speed above 10 mph. I can hear the tires grinding on the road. Tire pressure set at 48psi. Should I ask tesla to look into this?
Have you had an EV before? If not, then that's probably the road noise that you could never hear because of engine noise.
the Model S isn`t better, though. Seems like that`s one of the woes of not having 100+ years of car manufacturing experience.
I recall that as well. It was written somewhere...on here??.. someone stated that the Model S was a $35, 000 car with a $40, 000 battery in it.Well one has to keep in mind that the battery is very expensive.
They are trying to cut corners in other areas as unobtrusively as possible, but still keep the car price & feature competitive in segment.
When I hear some wind or tire noise, I think to myself that I spent my money on fancy battery tech instead of more sound deadening.
I just had a 2018 Model S 100D loaner, and I was very impressed with how quiet it was. The car is noticeably more refined than earlier models.Threads like these really confirm me in my conviction that I can under no circumstance buy a Model 3 without test driving it beforehand....
I can`t even describe how furious I´d be if I bought an EV in the price class of my previous E-Class and it turned out to have higher in-cabin dB than the Merc. Road bump compensation and silence in the cabin are the premium attributes to me.
Edit:
Found this in another thread:
Model 3 - January 2017 build, 18" wheels:
0mph, fan off, 30 seconds: avg 51.2dB, max 52.6dB
0mph, fan set to 3, 30 seconds: avg 56.9dB, 58.5dB
65mph, fan off, on smooth surface, 10 seconds: avg 82.8dB, max 85.0dB
F*** that`s bad.
The E-Class / 5 Series have ~60 at those speeds. 20+dB difference is tremendous.
Model S - December 2017 build, 19" wheels:
0mph, fan off, 30 seconds: avg 49.6dB, max 51.8dB
0mph, fan set to 3, 30 seconds: avg 68.4dB, max 68.6dB
65mph, fan off, on smooth surface, 10 seconds: avg 84.0dB, max 87.4dB
I used to have a 2005 Mercedes E500, and I also had a 2016 Tesla S60D. The Tesla was much louder. In the Tesla, passing motorcycles and busses were as if the window was full down even when it was full up. In my Mercedes, a loud motorcycle or even jackhammer could be outside my closed window, and while I could hear it and identify it, it would be a mere wisper. Furthermore, the Mercedes had better heat insulation.Threads like these really confirm me in my conviction that I can under no circumstance buy a Model 3 without test driving it beforehand....
Edit:
F*** that`s bad.
