Trick to keep your HVAC system fan speed at 11 even in range mode
Discussion in 'Video' started by islandbayy, Dec 16, 2013.
Tags:
  1. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    #1 islandbayy, Dec 16, 2013
    This trick/software bug will allow you to keep your fan set to 11 (despite the car saying it's #8) while having the heating and cooling system in Range Mode.
  2. EdA
    EdA Model S P-2540
    Massachusetts
    Thanks, I had no idea the fan speed went to 11!
    Guess I'm a range-mode addict.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Nice trick, thanks!
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    Great tip! I wish Tesla would not limit the fan speed in Range Mode as it can't make that much of a difference in energy consumption anyway.
    Speaking of Range Mode, why do they even call it that when the dash HVAC display calls it Eco (or Econ) mode? Let's call it one or the other, and I vote for Econ since Range Mode sounds like something else entirely.
  5. Doug_G
    Ottawa, Canada
    +1. I never thought this made any sense. Fans do take some power, but nowhere near significant compared to the heater. They could simply limit the auto setting to 8, but let you manually dial it to 11.
    Yeah, especially since there was an utterly different Range Mode on the Roadster. (Though most people have never driven one, I guess.) Eco Mode would be clearer, I think.
  6. patp
    patp Member
    Canada
    Totally agree. It should be called Eco and easily accessible from the main screen without going in deep settings.
  7. Doug_G
    Ottawa, Canada
    +1 on the deep settings thing. That's annoying. Especially since I turn it off during charging - I've heard reports that it limits pack heater power too, which I certainly wouldn't want while the car is plugged in!
  8. dmetcalf
    dmetcalf S258
    Merritt Island, FL
    Good tip. I stumbled on this over the Summer inFL, but did not know how to recreate it...
  9. Seven7
    Seven7 Member
    Sarasota, Florida
    Thanks for the useful tip!
  10. islandbayy
    No problem. I'm keeping em coming. I have over 80 Tesla/ Model S videos on my channel now and more to come! I always appreciate thumbs up ratings on the videos, helps the search rankings.
    Cheers!
  11. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    Thumbs Up. Good tip
  12. islandbayy
    Grazie!
    This trick really is nice with the AC. Range Mode AC has kept me freezing even when we had 100+ Degree days. Takes SLIGHTLY longer to get it cold in the car, as in, maybe a few minutes difference. Plus, you can always start it off with range mode off, then flip range mode on once it's at desired temps. Energy reduction I have found to be SIGNIFICANT! And coupled with FogPro on the windows, recirculating interior air to allow use of #11 on range mode in the winter without windows fogging cut my winter power usage by an additional 25%, even more when I can run the heat without the pack warmer kicking in.
