TRIP REPORT
Some stuff to report, and a couple of funnies. But basically it was a no brainer, which is how it should be of course.
I left armed with Spreadsheets of how much charge I needed to depart each Supercharger, courtesy of A Better Route Planner which I had set to 5C and 5 MPH wind. Also what SoC I should have at intervening Superchargers, in case I was "critical" at that point and could top-up. Actually I don't think that was necessary at all, using the dashboard "Energy Graph" to show on-arrival prediction I could easily slow-down or add a stop if range became critical.
I took the car to have the Winter Tyres fitted a few days before - not got around to it, nor needed it, this Winter. The guys there laughed, but we then had heavy snow the following day so hopefully they were thinking "How did he know that?"
Dunno if the Winter Tyres were more thirsty than the standard ones, but we had torrential rain most of the way there, and worse on the way back. Maybe they shifted the water more efficiently than Standard tyres would have done? The extra consumption was not as much as I would have expected
Rather than aiming to arrive with 10% at the next charger I preferred to charge to 70% (unless more required) assuming that charging is roughly linear to 70% and a bit slower to 80% and then much slower above that.
On the way out we stopped overnight (which netted me 15% - 100% "free" (in terms of time), and then at a Supermarket for a full set of self catering supplies - there is a huge Carrefour right next to the Beaune Supercharger 62% - 94%, so that was "free time" too.
On the way back we did the trip in one day, so no "free" overnight stop, but our lunch took an hour and a "free" 16% - 94%, and then we had 10 minutes wait at the Tunnel so I suppose that 22% - 24% was "free" too.
Upshot: well worth planning-in any "free" stops like that. Limits the hotels to ones that have charging ... but we saved over £100 each way on fuel so treated ourselves on the proceeds ...
Folkestone : I figured 20 minutes was long enough to get from Charger to Train. We got stopped for swab-check, but I don't think that added much delay, but we were first in lane for the next crossing, so probably need to leave 30 minutes from Charger to Train Departure time. Pity as being able to accurately judge maximising charger dwell time is obviously a benefit. (Better on way back as there are two chargers at Flexiplus lounge, and they are "air side" so only need to allow 20 minutes and nothing to add delay).
Urvillers is shared charging for North and South traffic. However, the charger placement "over at the far right corner" of the car park means that care is needed when leaving to travel SOUTH as you have to go back into the car park towards the facilities, and then double back, and only then find the right exit. On the way through the car park to get to the charger look out for the sign (to Reims) and then it will be obvious when you leave. Its all signposted, but in the way that I find much of their signage : obvious to the French and obtuse to Brits. When going NORTH the sign to CALAIS is a bit more obvious, but not much (drive through the gap towards the lorry park). Looking at Google Street View the area where Chargers have been installed was the "exit route" towards Reims, and the service roads have been remodelled/bodged as a cut-through, which explains the convoluted rigmarole.
Châteauvillain got in a muddle there too. It was on my list to stop at (on return NORTH leg). Clicked on it and pressed NAVIGATE TO. When we were some distance away I could see that the "route line" was going past the charger and doubling back, so I realised I must have pressed "wrong carriageway" and picked the South Supercharger instead. I couldn't figure out any way to find the North one (**), so assumed [wrongly] that there wasn't one. So I put CALAIS into SatNav and it choose Troyes to recharge. We had enough spare to reach Troyes, but my Planning notes had Troyes marked as "not directly on route", So I just shrugged and said Oh Well! (we'd had a week in France by this time!! ...)
I was getting tired and we decided to swap drivers and I said "
Lets do that at Châteauvillain in case the charging is mixed" (given that it didn't actually say NORTH / SOUTH in the Supercharger name). Sure enough we could see the SOUTH chargers on the other side of the concrete barrier, and then we happened upon the ones on our NORTH side, so we charged there instead of Troyes. It turns out that the North / South services have different names ... no indication of North / South, so that may well catch other people out too. I suppose if you just put CALAIS into SatNav you will at least get Superchargers on the right side of the road!, except I'm not sure Troyes was the better choice of stop given the detour off the Autoroute.
South = Aire de Châteauvillain - Val Marnay
North = Aire de Châteauvillain - Orges
Eurotunnel Coquelles. Charged at Flexiplus Lounge. That is "air side", so easier to guesstimate time to platform/loading and thus charge until the last moment. My spreadsheet had minimum charge levels for Maidstone, Stanstead and Home but I had decided I was better not to miss a train so long as I could make at least Maidstone (also, as always, charging nearest-to-home is best as easier to reliably predict required charge, whereas further from destination needs more "contingency"). I've done some sums subsequently and I think that is the wrong approach. As it turned out I got the last stall at Maidstone so had to pair, and then cars were waiting behind me.
Maidstone is 7 minutes In/Out (get off motorway, get to Supercharger, get into/out of the awkward stalls, and back to motorway). Missing a Chunnel Train costs 20 minutes, so 13 minutes @ Maidstone charging and you are evens, and if already in a stall at Flexiplus then that avoids risk of all-stalls-full etc. etc. at Maidstone ... and Flexiplus lounge has amenities, whereas there is nothing at Maidstone, less so in the pouring rain we had ...
Mountain descent regen
Not heard of this before, so not sure what to make of it.
One day we decided to drive round to an adjacent valley. Weather was perfect, fresh fall of snow, we set off for the 30 minute drive half and hour before the lifts opened ... and avoided all the crush getting "up and over" by lift. Also had the car to mooch around après ski, and not have to rush back on last lift. But this was unplanned, so car was "cold".
Car was in garage, dash said 2.5C outside.
I had absolutely no Regen, so used friction brakes all the way down. That is far worse than a low gear in an ICE! On the way up the other side I realised I still had Range Mode on from the journey out, and turned that off, but I only had a small amount of regen by the time we got back up to the top. (Maybe Range Mode=Off would have given me some Regen sooner on descent?)
So basically on the way down left with 80% and got to the bottom with 80%
On the way up used 80% - 65% for 11.5 miles, and only got a bit of regen back by the destination. Battery Heater didn't come on, temperature was 0C in the valley and -5C at destination.
Parked in underground car park, and for the return I put the climate on (in the car, not APP - dunno if any difference) for 45 minutes whilst we wandered around the shops. That bought the battery heater on for 30 minutes and reduced SoC 64%-60% (stayed at 60% for the further 15 minutes whilst maintaining climate only). Outside temperature was 1.0C
Set off with about 2/3 regen, but as went down the mountain that reduced to about 1/3rd
Gained from 60% - 63%
but some friction brakes required. Battery heater did not come on.
For the journey home I charged for 1h45m before departure (battery heater came on, when I put Climate on, for 8 minutes during that). Climate on for total 50 minutes before departure (reduced SoC by 2% even though plugged in @ 10AMPs)
Set off with full regen - although if flashed on and off 2/3rds for a bit, and then stayed on at 2/3rds for the rest of the decent. Not sure what would be necessary to get 100% Regen for the whole of the descent??
Battery heater did not come on during the journey. Temperature was 5-6C for the first hour, then 10C for the rest of the day, and in the evening fell to 5C. Range Mode was off for the whole descent (need to remember to turn it back on for the journey, if you find it useful)
If you can be bothered, it might be worth selecting PARK momentarily at the bottom when changing from Decent to Ascent/Flat, so that TeslaFi records it as two drives (or maybe there is a way to SPLIT a drive) for separate Wh/Mile etc..
Chateau De Courban is a delight. You must eat there - allow plenty of time, it's not fast food by any means, but every course is an absolute delight. Do not skip pudding.
The whole place has a lovely atmosphere.
We have only stayed there in the summer generally on the return leg.
Love the place...
Good shout
@Mr Miserable
3 x Tesla Chargers, one more than Tesla Website ... but that was the only one working! Plenty of faded-glory in evidence, but of course that is normal-for-France. (Trip adviser: "
Some guests commented maintenance could be improved" ... no idea what they were expecting differently
dans la France!!)
Restaurant was excellent (its got a Michelin whatsit). Pudding had the red love-heart decoration superglued to the plate in some crafty way such that it remained after thinking I had scraped every last bit into my bulging stomach. Not sure what the 3 suits at the table next to us were going to make of that, sadly we were gone before they got to that bit!
Car charged overnight at 72 AMP (presumably an M3 would not utilise all of that, but still plenty enough hours during the night of course)
I set the limit to 90%, and then increased it the following morning to 100% an hour before we left, and put on Climate 15 minutes before departure (6C outside)
