Completely unrelated to the issue but somewhat related to the breakers… you should look into a Ting monitoring tool if you remove the arc fault breakers.
www.whiskerlabs.com
This will help you to learn if an arc fault is happening in your home. So while you may not be protected by the breakers, you’ll at least get an alert on your phone that something ain’t good.
State Farm is partnering with Ting to give policyholders one for “free” under a pilot program with their customers.
Help protect your family and home from electrical fires. Homeowner policyholders can sign up for Ting, free!
www.statefarm.com
The good is the program will give you a free home monitor. The bad is State Farm will learn if your home has experienced an arc fault. Which means they’ll follow up with you if one is detected. Presumably State Farm will want to see the homeowner fix the cause / outcome of the arc fault or risk higher premiums.
I guess if the poco going offline (and Powerwalls going into full backup) throws an arc fault on the Ting, it could be mega annoying.
