Trouble with Fob Linked Driver Profile
Discussion in 'Model X' started by DrivingTheFuture, Jan 5, 2017.
Tags:
  1. DrivingTheFuture
    United States
    We can't seem to get it to function properly, seems to get stuck on one setting (for example even when we leave the house and my fob is at home, when we leave office my wife gets in with her key and seat goes back to my profile. The reverse situation is a painful one! When I get in and it adjusts back to my wifes profile (knee crushing!)
    The only thing I can think is my fob is not actually fob 1 but is fob 2, however I tried turning feature off and then pairing profiles with driver keys again when we were away from the house with only one key with us and it still didn't work. I think it's a software issue and was wondering if anyone has had same problem. Thanks!
  2. Lou gagna
    Lou gagna Member
    Princeton, NJ
    Same problem here. I set my profile at the delivery and connect with the FOB (was also supposedly Fob 2).
    Then when home, while my fob was away, we set my wife's profile and linked it to the fob she had (was also shown as Fob 2).
    Worked fine until I show up with my FOB and the car went into my wife's settings.
    Now (I did not try that) since the user manual states that a battery depleted FOB can start the car if placed in the cupholders (driver's armrest cup holder):
    Have you tried putting the FOB to be linked in there when doing the profile association?
  3. DrivingTheFuture
    United States
    We had same issue both were shown as fob 2, but then I re-paired both and was shown as fob 1, fob 2 respectively but still had same issue. At this point we have it turned off but I didn't know the cupholder trick with a dead fob, that's handy!
  4. outie
    outie Active Member
    SoCal
    As a remedy, just set one fob up and leave the other one unset, whoever has longer legs.
  5. DrivingTheFuture
    United States
    It was because of my wife's complaint that I had to turn both off :( I have longer legs
  6. canadian79
    canadian79 Member
    Colorado
    Same problem for me - hopefully a software fix in the next update. I'll try to submit a bug report if no one else has done so yet.
  7. cclaygo
    cclaygo Member
    United States
    I have the same issue, but it's random. I chalked it up to my wife getting in the passenger side with her key fob in her purse before I got in the drivers side.
  8. MikeQ
    MikeQ Member
    The Real World
    We just took delivery of a new Model X and initially the driver profiles worked perfectly. Two days later, my wife’s key fob died due to a dead battery. Replaced the battery and both key fobs showed up as Key fob 2. I removed the batteries from both of them, deleted the profiles and moved the remotes away from the vehicle. I then took each one to the vehicle independently. I created new driver profiles and each key fob was detected and shoed up correctly as 1 and 2. I thought all was good but now the car isn’t switching between profiles when a remote is present. It clearly can tell that either fob 1 or 2 is in the car as it shows up in the driver profile menu. However, it never triggers the profile. I found that unlocking the vehicle causes it to switch to the appropriate profile but I never do that since I’ve got the auto-present setup to unlock and open the door.
    I called Tech support and they had me reboot the system. That didn't work so they said factory reset it. I did that and I still have the same broken behavior.
    Kind of frustrating that things are so easily broken.
    I also think Tesla should give us the ability to back up our setting so after a factory reset, we can restore without having to manually re-do everything.
  9. DrivingTheFuture
    United States
    We still have issues with it on a weekly basis even though I turned off the feature long ago, I've just given up on it
