Trouble with homelink/garage door under 6.1, anyone else?
Discussion in 'Model S: User Interface' started by ADN_ModelS, Jan 23, 2015.
  1. ADN_ModelS
    ADN_ModelS Member
    Newton, MA
    After installing 6.1 on my Sig P85 the homelink garage door didn't work any more. The icon would show up at home, but touching it would not open the door. I figured that it had just "forgotten", so I deleted it and tried to re-add it. Now, when re-adding it, it just sits there, and never learns the remote: meaning, I invoke the learning mode, go to the front of the car and press the garage door button on the remote, but it never flashes the lights indicating that it's learned the code.
    I was wondering if anyone else has run into this trouble, or if it's specific to my car. Any thoughts are appreciated.
  2. Majerus
    Majerus Member
    Illinois
    My garage door wouldnt open unless I was real close to it after 6.1 update, I thought i was that specific door, but the other side seemed fine. I would call service and ask them to look at logs.
  3. Killface
    Killface Member
    Tempe, AZ
    Uh oh. Mine's been acting a little finicky for the last week or so, and I didn't get the update until last night. I'll let you know if mine gets even worse.
  4. DCWitt
    DCWitt Member
    Watseka, IL
    As I was leaving yesterday, the door went up just fine, backed out of the garage and the door would not go down. I got out and walked in to manually close the door. When I arrived back home, the door opened and closed normally and has worked correctly since. This is the first problem I have had with homelink in my 22 months with my P85. I had just installed 6.1 a few days ago, so I probably should do a bug report.
  5. wayner
    wayner Active Member
    Toronto
    I have had issues since upgrading to 6.1 but eventually the door did respond. But I don't have a huge pre 6.1 sample to compare it to.
  6. commasign
    commasign Active Member
    Davis, CA
    The homelink on my P85D feels a lot weaker than on my old P85. Sometimes it takes several tries before opening or closing the garage whereas on my P85, it was pretty much 100% responsive.
  7. jerry33
    Texas
    Seems about the same on my S85.
  8. Notacarguy
    Notacarguy Member
    Houston
    No issues for me
  9. clmazin
    clmazin Member
    Southern California
    This won't solve any problems for people who have already programmed their HomeLink and are encountering issues, but if you're reprogramming and not getting the flashing headlight confirmation, make sure you're holding your remote no more than an inch from the front bumper.
    The illustration shows the remote about a foot away from the bumper, but that never worked for me. Getting it really close? Worked right away.
  10. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I haven't had a problem. I occasionally have had to press it a second time, before and after the update, but pretty rarely. Just updated on 1-21
  11. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Working the same on my P85D on 6.1 as it did on my old P85 for years.
  12. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    I do hope that all of you with these issues are reporting them to Tesla...
  13. ADN_ModelS
    ADN_ModelS Member
    Newton, MA
    So, thank you to the advice from someone on this thread, I was able to reprogram the home link. Key was to hold it SUPER close to the bumper. Now it works, but 6.1 does seem less powerful, so I need to be closer to the garage to open it.
