Truck bed Suggestion
Discussion in 'Cybertruck' started by Jrogville, Dec 6, 2019.
  1. Jrogville
    Jrogville Member
    High Springs, Florida
    I’ve read several sources criticize the difficulty of reaching items toward the front of the truck bed because of the height of the wings. You would normally reach those things from the side of the truck.
    What do you think of addressing this by providing a slide-out truck bed rather than a fixed one that would bring those items further back where the wings are not as tall and therefore reachable from the side?
    • Disagree x 1
  2. Barklikeadog
    Barklikeadog Active Member
    PA
    instead of climbing into the cybertruck, robot arms could extend out, pick us up, and place us in the driver seat. This is a good idea
    • Funny x 3
  3. Electruck
    Electruck Member
    WI
    Also, pease provide a dog, the breed of my choice to be placed into the back for retrieval duties. My arms are short.
    • Funny x 3
  4. keeney
    keeney Member
    Minnesota
    Many companies make all kinds of slide out drawers and trays for pickup beds. For example: BEDSLIDE truck bed sliding drawer systems
    Too me, they seem awkward to use. In many parking situations, you may not have room to even open the tailgate, much less slide out a big drawer. Say in your garage where the truck barely fits, you need to grab the kid's basketball bag and shoes that were tossed back there because hauling sweaty teenager athletic funk back in the cargo area keeps the interior a lot fresher.
    In a normal truck, that front corner of the bed closest to the driver's door is such a convenient spot to carry stuff. The issue is not a deal-breaker, but it will annoy me and make me think of my CT as being less than the perfect design it could have been (for how I will use it).
    I seem to be the deep minority here on this topic. I suspect part of it is the majority of people here have never owned an actual pickup truck. Another source of strong opinions seems to be the beliefs that the side sails are necessary for structure. Also, I see the large majority of pickup trucks these days driving around with tonneau covers on them which is similar in terms of the loss of convenience. So statistically, Tesla has made the right choice in favoring aerodynamics (for range) over convenience of access to the cargo bed. Its just not the choice I want.
  5. JBee
    JBee Member
    WA
    Bed tray would work fine. It really depends what you put in there, if you want to keep it, and how organised you are. A conveyer would solve the draw space issue as well, I'm not sure what you need to take out in a parking lot, normally you put stuff in to go to a job. I think the frunk and sail storage well be fine for the smaller gear and tools, and the tray should mostly be used for materials. I typically only run drawers, and/or bedslides to keep things organised.
  6. sparcs
    sparcs Active Member
    Couldn't this be done in the aftermarket? some sort of slide out insert?
  7. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    #7 muleferg, Dec 7, 2019
  8. geoffmanley
    geoffmanley Member
    Porter Ranch, CA
    That describes me perfectly, but I still want the truck despite never having owned one. I'm sure I will have a few gripes about the vehicle once I have used it for a while. Although doesn't the truck have a small cargo area under the bed? If so I could put my soon-to-be teenager's stinky athletic funk in there.
  9. keeney
    keeney Member
    Minnesota
    To be sure, what I am talking about is not world-ending inconvenient with the CT, just slightly annoying. Similar to any truck with a cover, just walk to the back, crack open the tailgate or the roll top and toss stuff in and out from the back. No worse than an SUV.
    The inconvenience happens when that one thing you need (e.g. the basketball) has rolled or slid to the front during driving and you can't reach it. Then you have to open it all the way up and climb in to retrieve it.
    My dad had a cover on his truck and kept a boat pole/hook in the back for retrieving things.
  10. geoffmanley
    geoffmanley Member
    Porter Ranch, CA
    Note to self: get boat hook on the way back from the CT delivery.
  11. woodguyatl
    woodguyatl Member
    GA
    #11 woodguyatl, Dec 7, 2019
    I feel the same way. That said, if the "saddle bags" on the truck are roomy they will probably meet my needs.
  12. Barklikeadog
    PA
    They sell em already, $15
  13. Barklikeadog
    PA
    This is a big jump for a non truck owner.
    1. they are big
    2. can't park in tight spots, best to park at the end of rows or farther away
    3. backing in is the best way to park, do not pull in with a truck
    4. you can't cut corners. you CAN'T cut corners!
    5. Go to an empty lot and practice backing up into spots. without using cameras. maneuver backwards while looking over your shoulder out the rear window. re-wire your brain for knowing how large the vehicle is
    No that's not me
    6. They are wide
  14. geoffmanley
    geoffmanley Member
    Porter Ranch, CA
    Yeah, the parking situation is most concerning. Although I looked at the specs and it only looks to be about 2 inches wider than an MS, so it's the monster length that will be tough. No matter, I'll learn as I go as it were.
  15. Cyber_Dav
    Cyber_Dav Member
    SoCal
    I only wish people here were as considerate as you. Here they park nose in in the spots marked 'compact cars only'
  16. Barklikeadog
    PA
    Don't cut corners cyberdav!
  17. LJS22
    LJS22 Active Member
    Texas
    I was going to post that as well. If it’s small enough to reach over and set something in the bed then it will likely go in there. If not you slide it in the back, not a big deal
  18. ThomasD
    ThomasD Member
    florida
    External tailgate Handle and a Remote key fob to open cover and lower tailgate
    • Disagree x 1
  19. Barklikeadog
    PA
    Wasn't that long ago some of us truck owners (not me) thought tailgate steps and auto opening gates were sissy luxury items.
    now we all use them and like em.
    They have auto opening covers now. I wouldn't want one. retract covers are loud when driving, they tend to drop water and snow on your contents, and they leak. all covers leak, but retract covers leeaaakkkkk.
  20. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    Why not use the Sail Pillar to for that purpose? Its already in the design of the vehicle.
