Trunk Closing Problem
Discussion in 'Model X' started by Oloron, Jul 25, 2016.
Tags:
  1. Oloron
    Oloron Member
    Boston, MA
    We picked up our new 75D last Friday and encountered a problem I don't remember seeing described here. (We also have one FWD door with the phantom "obstacle detected" problem, but that seems sadly common.)
    Around a third of the time when pressing the button to close the trunk, it will go all the way down, the latching motor will start to make noise and the door will start being pulled closed as normal. Then, there will be an "obstacle detected" beep and the door will release and open about an inch. (this is with nothing in the trunk area)
    Gently pushing the door closed will cause the latching motor to engage and close it, but it's annoying to stand and confirm that it's closed properly every time (and then have to close it manually the ~30% of the time when it doesn't work.)
    Anyone have a similar issue? The car is going into the SC for a (increasingly long) list of issues on Thursday, but i was curious if others have had similar problems.
  2. vandacca
    vandacca ReActive Member
    Hamilton
    I don't have this issue, but your description sounds like something is causing some additional resistance to the rear hatch, during the latching process.
    1. Check the seals around the perimeter to see if they are folded over or not properly seated.
    2. Make sure that there isn't anything getting caught between the door and frame.
    3. Finally, there are a couple of "stoppers" or bumpers that can be adjusted. You may need to rotate them clockwise a half-turn to lower them enough to allow the door to close without additional resistance.
  3. Oloron
    Oloron Member
    Boston, MA
    Thanks! I'll check these.
  4. Oloron
    Oloron Member
    Boston, MA
    Thanks again - looks like it was #3. (Not sure if it came that way or if one of us bumped it or spun it when checking out the car)
  5. vandacca
    Hamilton
    Glad to hear it was a trivial fix. Enjoy!
  6. Brandon332
    Brandon332 Member
    @Oloron sorry to hear. Just out of curiosity, what are the other issues with the car? Maybe I can offer some advice
  7. Oloron
    Oloron Member
    Boston, MA
    The 2 remaining are:
    - One FWD stops short of closing with an "obstacle detected" error about 30% of the time. No effect when recalibrated.
    - One middle row seat does not tilt. (Forward and back works fine)
    It's going into the SC tomorrow.
  8. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    Had same issue with FWD.....team replaced defective sensor and it seems to work now (small sample size though).
    Unfortunately, front passenger door latch just failed (just picked up this week from SC after 2 weeks in repair) and none of the calibration techniques worked. Door had been repaired for window/seal issues....perhaps SC techs didn’t calibrate properly? Tech at National Service Center said they can do some remote fixes to doors now but his approach didn’t work. Hopefully, someone from Dania Beach can visit shortly. Can’t/won’t drive vehicle in which a door won’t lock. Getting old, will be 3rd time at shop since pickup in early May (1 week, 2+ weeks, ???? this time).
    btw: test out your trunk to ensure that a “pinch” gets trunk to stop/reverse. Mine was broken and it wouldn’t stop closing ( a danger to anyone using and not aware). SC did successfully fix that for me....
  9. Oloron
    Oloron Member
    Boston, MA
    Thanks for the info. Luckily we live about 15 min from the SC, so pretty easy for us to take it in - just a pain and a bit disappointing.
