Trunk Latch Failed
Discussion in 'Model S' started by Doug_G, Dec 10, 2014.
Tags:
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Tonight my trunk latch failed. I went to open the trunk and it went clunk whirr clunk and stayed closed. Tesla had earlier made some adjustments to the latch to try and stop that from happening - wasn't the first time. I just hit the button again and it opened.
    But when I went to close it, it didn't latch. And nothing I can do will make it latch. Tesla is going to retrieve the car tomorrow.
    Anyone else run into this before?
  2. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Never heard of that happening Doug. Out of curiosity though, if you start or try to drive the car (slowly!) are you getting the dash warning alert that the trunk is open?
  3. Kalud
    Kalud Active Member
    Montreal, QC
    ... but don't go 100km/h in reverse, your know what would happen! #sarcasm
    Never heard of that issue Doug.
  4. Brass Guy
    Brass Guy Member
    Holbrook, MA
    My trunk latch broke and was replaced in March of this year. Rear hatch would not latch shut. Non-tech, so not sure if that's your issue. The good news is no exhaust fumes were sucked in while I drove to the SC.
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I don't recall anyone posting about a trunk that wouldn't latch before. Very unusual. I am also curious to know if you see onscreen warnings about a rear trunk not closed, and if there is an audible warning. Sounds like there should be.
    @BrassGuy, relieved to hear that you did not suffer from carbon monoxide poisoning
  6. Morristhecat
    Morristhecat Member
    Burnaby, BC
    I had a problem with the trunk latching on my car when I firstpicked it up on delivery almost 2 years ago. The technician simply adjusted a few things, it was a five minute fix.
  7. scottm
    scottm Active Member
    Canada
    On which car?
    At how many km on the odo?
    Would you say you are a heavy trunk user (every trip, twice).. kinda thing?
  8. wcalvin
    wcalvin Member
    Seattle WA USA
    Maybe the manual (emergency) release cable kinked.
  9. russman
    russman Member
    I wonder how much that would cost out of warranty to fix. Really need to come to a decision in the next year on getting the extended warranty or not, which I think is expensive at the $4k + deductible price. At $2.5k no deductible, I would do it in a heartbeat, as that's around what I paid on my previous 3 cars.
  10. Atebit
    Atebit Member
    PA
    Tesla replaced my trunk latch a fee months back because it was making a terrible straining noise when it went to latch down the trunk. Sounds much better now & no further issues. I've had the car about nine months, two open/close cycles per trip typically.
  11. Doug_G
    Ottawa, Canada
    Sig Model S #2006. About 37,000 km. Yes I open and close the trunk frequently.
    - - - Updated - - -
    And off she goes to Montreal Service. They didn't have the trailer available on short notice, so it's on a flatbed - a first for me. Seems ironic since the car was quite drivable... except the trunk was always open and you can't lock the doors as a result.
    Took us an hour to figure out how to hold the trunk closed - figured it out on the third attempt. We popped off the cover of the internal mechanical trunk release, put a hook in there and put the strap around the floor section between the main footwell cubby and the charger accessory bag cubby, then back to the trunk release with another hook.
  12. Doug_G
    Ottawa, Canada
    It's back home again. Trunk latch now works smoothly - better than it ever did before.
