Trunk latch sticks and struts are weak
Discussion in 'Roadster 2008-2012' started by asgard, Jun 2, 2016.
Tags:
  1. asgard
    asgard Member
    One side of my trunk does not open consistently. It sticks every other time. I have greased the latch but that did not work. Seems like the electromagnet may be failing.
    Also, the struts that lift up the latch are getting pretty weak. My car only has 17k miles. Seems like these parts were not built to last.
    Are better aftermarket supplies available or am I better off going to Tesla under warranty?
    Thanks.
  2. MileHighMotoring
    Parker, CO
    Your car is still under warranty? Then let them fix everything. If not, hydraulic struts failing isn't (in my vehicular experience) indicative of cheap or substandard parts, it's pretty common and easy to replace.
  3. wiztecy
    wiztecy Active Member
    Don't ever grease the latches, it attracts dirt and dust. Reason the latch on one side is sticking is that the cable needs to be adjusted on that side, I created a thread on this issue of the stuck trunk issue.
  4. hcsharp
    hcsharp Active Member
    Vermont
    +1. Don't grease the cables either.
