trunk lid lift supports
Discussion in 'Roadster 2008-2012' started by jordanthompson, Mar 3, 2013.
Tags:
  1. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
  2. X.l.r.8
    Toronto/Miami
    No year difference in the parts listing. the shocks are the same, great find for $30 a piece.
  3. JohnGarziglia
    Reston, Virginia
    A confirmation here that these trunk lifts from Advance Auto work perfectly on the 2.5.
    Just put "D4247" into the search bar on the Advance Auto website and it will show you which stores in your area (assuming there are stores in your region or country) have them in stock. Otherwise they will ship. The most difficult part is getting the old ones to pop off the ball joints -- the new ones just "click" on.
    Now my trunk lid pops up fully rather than anemically going up 3/4 the way! Thank you "JordanThompson" for posting above!
  4. backmost
    backmost Member
    Middletown, NY
    Is there a reason the struts get so anemic in the winter? I know my car spent most of its life in sunny California before coming here to gloomy New York, but it seems it's a common issue.
  5. ML Auto
    ML Auto Member
    SW Florida
    You need to remove the spring clip to take them off, as they are only designed to snap on-not off.
  6. Rotarypower
    Rotarypower Member
    Cary, NC
    PV=nRT ;)
  7. backmost
    backmost Member
    Middletown, NY
    Oh man that takes me back!
  8. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    I found that I didn't need to remove the spring clip as much as just pry it back a bit. Same for installing the new ones.
    I just did this (the Advance Auto Part #D4247 is correct, btw). I found that after replacing just one of the struts, and keeping one of the old ones, the trunk opens just fine all the way now. So, I haven't yet replaced the other strut and may not for a while.
    I got a coupon for Advance Auto - "PS20" for 20% off. Probably will still work since it was given to me when their site was down as an incentive to come back later.
  9. slcasner
    slcasner Active Member
    Sunnyvale, CA
    #29 slcasner, Nov 17, 2018
    I ordered the Advance Auto Part #D4247 as well, and can confirm now that they fit fine on a 2008 Roadster 1.5 even though the web site lists the part for 2010 and warns that the part "might not fit your car". Thanks to @MLAUTO about removing the spring clip; this was easily done with a screwdriver and needle-nose pliers on the upper end, but a bit trickier for the lower end down inside the body work, especially on the passenger side where the coolant tank occupies part of the access space. I managed to get that one started by tapping on a long-shank 1/8" straight screwdriver, then pried it loose with a large screwdriver. The only problem was that the clip got away from me before I could catch it. I hope there is nothing down below that it might interfere with.
    p.s. As I was looking around on their web site a coupon for 25% off popped up. :p
  10. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Pretty certain the trunk is the same on the 1.5 and 2.X.
  11. steve873
    steve873 Member
    illinois
    Just order the same set from advance auto parts. Used promo code “sppf18” for 25% off $50 or more order. Got the set for $47.79 shipped.
  12. MCroadster
    MCroadster Member
    I installed them on my 1.5 and it works perfectly. Installation was pretty quick, but did have a bit of trouble pulling out the lower clip on the original set. I started out using a flathead driver, but what worked for me was wedging a straight dental pick between the clip and the joint housing.
    At first I was a bit concerned with the higher force value, but it seems to be just fine, and the Strong Arm documentation states the strut replaces units with a force from 40-49lbs.
    Overall great find!
  13. Roadster
    Roadster JdeMO Powered
    SoCal
    #33 Roadster, Nov 27, 2019
    I was making adjustments to my trunk lock actuator and figured I'd address the weak OE Stabilus struts while I was at it. I ended up going with a pair of Suspa C16-08260 struts that I found on Amazon for a whopping $19.80 USD :D
    Suspa C16-08260 19.7" Gas Prop/Strut
    Set of Two, Force 60 lbs Per Prop/Strut
    Force 120 lbs Per Pair, Made in USA
    https://www.amazon.com/gp/product/B007MUY6LA/
    Perfect fitment and rated at 60 lbs each so they definitely have no problem opening the trunk all the way :) Made in the USA as well.
    The job took only 10 min and all you need is a flathead screwdriver to pry the retainer springs up a tad to clear the mounting nipple for removal. The process did, however, require the sacrifice of one spring clip to the belly pan gods. To install the replacements, you simply push them on.
    Before and after video demonstrating strut lifting difference.
    • Informative x 6
  14. dhrivnak
    NE Tennessee
    I am pretty certain there is no change to the trunk lid on the Roadster models.
  15. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    Just figured I'd add my 2 cents as I went to the local Advanced Auto Parts / CarQuest and picked up two new struts. Per everyone's instructions, using a flat head screwdriver works and yes, the right one is a bit trickier as you have to maneuver around the coolant reservoir. But in the end, $50 for parts and about 15 minutes worth of effort and my trunk stays open again.
  16. Bunnak
    Bunnak Member
    Orange County, CA, USA
  17. backmost
    backmost Member
    Middletown, NY
    Getting the spring clip off was tough for me since I have paddles for hands and could not get a good grip. My solution was using a long spear shish kabob stick that came with our BBQ grill to thread through the spring clip and pry off.
  18. Bunnak
    Bunnak Member
    Here's a before trunk strut replacement video.
  19. Bunnak
    Bunnak Member
    Here's after just replacing only the LEFT strut.
    I decided not to replace the right one.
  20. drewski
    drewski Supporting Member
    SF Bay Area
    you might as well, unless you can return the 2nd one as it's probably going to lose some of it's gas charge sitting around.
