I found the stock trunk light to be annoyingly dim so today I went through my parts bin and rigged up something I'm pretty happy with. This picture is the before picture with only the left stock LED (right one removed). Camera on manual 1/15, ISO 800. This picture is with the right light replaced with a small LED strip, again camera on manual 1/15, ISO 800. In reality the difference is not as dramatic as the photos imply, however it is much brighter, I don't think I'll bother modifying the left one. The modification itself was quite simple, I took a strip of 12 LED and soldered a 2 pin connector to it. Removed the stock light and re-routed the wiring to the large support bar that goes across the top of the trunk cavity. Right in the centre of that is a bit of an indentation, that's where I put the LED strip. The LED strip is the peel and stick type, made it easy. I then used a bit of narrow duct tape to tidy it up a bit to prevent the wires from getting snagged by cargo. The stock LED uses only 15mA, this little LED strip now uses about 80mA hopefully it doesn't cause any issues.
You know they sell aftermarket LEDs right? Ultra-Bright LED Interior Lights https://www.rpmtesla.com/led-lighting-upgrades etc.
Yeah, I got the puddle lights from Abstract Oceans. I know it's not a huge amount of money, but after exchange and shipping (Canada) it adds up. This little light was done with stuff from my parts bin and I had fun doing it.
Yeah, and they are the same lights between the S and the 3. So I'll reuse them on the 3. Then I might just get some cool puddle lights...
Does anyone know how many milli-Amps the RPM Tesla or the Abstract Ocean Bright LED's consume? With the smart fuse system in the Model 3 if I replace more lights I'm concerned the unexpected increase in power consumption will trigger an error.
My solution..$7, out of sight, motion sensitive led strip: https://www.amazon.com/gp/product/B00J4EQVPG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 I have had this in my S for a few years and it's still on the original batteries - hadn't thought about it for a long time 'til I saw this post.
What controls the trunk light ? is it an old-fashion relay on a 5A circuit , or may it be a small FET , maybe inside some other unit that controls lights etc, which we do not wish to overload. ?
I guess that's a dead link... it was essentially this: AAA powered, led, decent attachment to stick on magnet strip. I placed it just under the package shelf in the S where you couldn't see it but opening the trunk was enough motion to turn it on. https://www.amazon.com/10-led-Wireless-Sensing-Anywhere-Magnetic/dp/B010Y1U1JO/ref=sr_1_4?ie=UTF8&qid=1539341844&sr=8-4&keywords=10+led+stick+on+motion
Just ordered this: https://www.amazon.com/dp/B01C5ISLP0/ref=cm_sw_r_cp_apa_dVx9BbN6WKB5G For $9 you can't go wrong.
Wasn’t there an issue with replacing the puddle lights and windows not opening a little when you open the door? I remember someone mentioning his window broke when he closed the door because it didn’t retract a little with the new puddle lights.
I received and installed my puddle lights in June from Abstract Ocean and haven't had any problems. My windows have never failed to retract (knock on wood).
