Trunk (maybe Frunk) aftermarket lighting
Discussion in 'Model S' started by jdowell362, Jul 31, 2017.
Tags:
  1. jdowell362
    jdowell362 Member
    San Carlos
    does anyone have any suggestions or recommendations for a better lighting source for the trunk?
    i am also interested in lighting for the frunk too, but unsure if it is as needed as the trunk.
    also, if this is easy enough for me to install then great, but if it is more complicated than normal, a recommendation for a place in the sf bay area that will install it would be great too!
    thanks!!
  2. bmah
    bmah New Moderator, Model S / Model X Forums
    Lafayette, CA, USA
    I would recommend the lighting upgrades from Abstract Ocean:
    Ultra-Bright LED Interior Lights
    Discussed extensively here on TMC all the way from concept to prototypes to end-user shipments:
    Improved Trunk lighting - Is there demand?
    Mostly plug-and-play depending on your car's configuration and whether you want to exercise the option to add certain lights that weren't originally present on your car. As for whether it's easy, my 10-year-old son and I had never done any modifications before and we found these (with one exception) a breeze to do.
    No connection with AO except as a very satisfied customer.
    Bruce.
  3. jdowell362
    jdowell362 Member
    San Carlos
    thank you for the info. that helps a ton. i will look into it and check it out.
    cheers!
  4. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Several YouTube videos on installation also by Erik on his Daerik channel. He installed them on both his cars. Very easy to DIY.
    Here you go:
  5. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Take a look here: Mods bottom of the page.
  6. MDR SEA
    MDR SEA 2015 Model S 85D...& loving it!
    Pac NW
    Here's some pix of my Frunk Light solution.
    Top pix is before, followed by after.
  7. mspohr
    mspohr Active Member
  8. MDR SEA
    Pac NW
  9. navinsiri
    navinsiri Member
    Central NJ
    I have these trunk lights by Norm and I love them. They’re super bright
