Trunk opens super high and solution
Discussion in 'Model S' started by sparkles1111, Sep 22, 2016.
Tags:
  1. sparkles1111
    sparkles1111 Member
    Palm Beach
    IMG_0655.JPG I found a solution for my trunk that opens very high and my garage ceiling being somewhat low.
    I installed some pool noodles on garage door so when I open trunk all the way, it doesn't catch on garage door but rather rests against the soft noodles :)
    My trunk doesn't come with the auto opener option so it just opens all the way.
  2. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    I thought you can set the opening height on the model S?
  3. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    you can. you manually move it to the height you want. then HOLD the button on the trunk. I think it has some beeps then.
    my bad, i just saw that this trunk is manual.
  4. JPUConn
    JPUConn Active Member
    CT
    Clever! - can you back into the garage?
    Though your charger looks to be setup for parking like you do.
  5. GuyGadois
    GuyGadois Member
    SLO
    I have that implemented too. I couple of other options...
    1) use pipe insulation found at Home Depot. Some versions will stick on the garage better than noodles because of the build in tape
    2) use those old blue camping sleeping pads and staple them to the garage door. They open and close like an accordion and give FULL coverage unlike just covering the metal like the OP pic.
    GG
