So its important to go back to the fundamental [no pun] logic of technical trading. You enter on a signal; you exit on a signal. You do not enter a position without also knowing both your stop and your exit. If you're entering a position without a stop and an exit, you're investing, not trading. You're simply hoping price goes your way eventually.
Agree this one isn't quite as strong as, for instance, the 200MA bounce a few weeks ago, but its setting up nicely all the same. The main thing though is that its a
setup, and not in itself a
signal. The best
signal (in this scenario) is a strong break out of the consolidation, like a morning gap up. A lazy meandering up and out of the consolidation is NOT an entry signal, as the probability of a reversal is higher with that kind of price action--so the play in that scenario is to simply not do anything and wait for the next setup.
FTR a much higher risk entry signal would be entering on confirmation of the lower trendline (= touch and reverse). I'll do that sometimes with stronger indicators but not with this particular set up. The idea there is (obviously) to enter at a lower price than waiting for the gap out (in this case); the risk is that because its much weaker than the gap out it could be a premature entry. That's important to understand, as there's
also a [slightly weaker] short entry signal if the price gaps down below the lower trendline of the triangle. So if you enter too soon and then the break happens but it happens as a gap down, you're not just going to open at a loss, you may gap below your stop loss and thus you may realize even more loss than you allocated.
Basically, the idea with this (and any setup) is that you're waiting for something to happen before doing anything by waiting for the strong entry signal. By entering prematurely you
might realize more profit, but at that point you're basically gambling that what you want to happen is actually going to happen. Gambling != trading.
Anyway, I'd strongly suggest reconsidering the mentality of "I'll wait another week or two before call buying". If you don't like a setup for whatever reason, a much more successful mentality is "I'll wait until the next setup forms". Don't define it by calendar days.
So--and I'll temper my actual thoughts to more muted, family friendly language here so as to not overly offend anyone's sensibilities here--selling a strangle with strikes on a consolidating channel is
****ing insane.
If there's one single thing that's more inevitable in the stock market than pretty much anything else, its that price consolidation eventually breaks. Often that break is the result of
just one of a litany of catalysts, some of which you've accurately outlined, and in many cases the temporal/X-axis element of that catalyst is completely unpredictable. Selling in general is a game of "I hope nothing big happens between now and expiration", where you're hoping exactly zero of the many catalysts trigger. Selling a tight strangle around a consolidating channel--beyond doubling your chances of losing (since a break in either direction screws you over)--is basically saying "I don't think
any of those unpredictable catalysts are going to come to bear before my expiration.
If
just one of those catalysts to...uhh...catalyze, the short position goes teakettle. Why not simply wait for that same
just one of those catalysts to signal a long entry?
Its also worth noting that selling a ~$50 wide strangle is like saying "I don't think TSLA is going to go up OR down ~3% between now and expiration". Step back and think about that--Less than +/-3% over many days if not a week or more. FTR, since I have the data at the ready, the average magnitude of TSLA price action from Friday close to Friday close is 5.7%. (Median is 4.6%). Sorted a different way, 66.8% of the time TSLA moves more than +/-3.0% friday-to-friday. So, and obviously depending on exactly when you enter, your weekly strangle more or less has a 2:1 chance of losing from a broad statistical analysis, and that's not even considering its sold against consolidating price action that is inevitably going to break...
