Or possibly level 2 (god I hope not).@GoTeslaGo: Could the level 4 dip correlate somewhat with the bottom? If so, then we could be near the bottom.
Below is the Elliot wave pattern generated by Fidelity Investments.View attachment 257898
Ok, here’s what I’m seeing with TSLA based on my interpretation of EW. So typically Wave 5 will exceed Wave 3, EXCEPT with a truncated wave 5 (rare, but happens). Assuming that Wave 5 is truncated, then we can start drawing the corrective cycle. The pattern is pretty much straight down, fits a Zigzag pattern, which is a classic 3 wave corrective cycle (A-B-C).
The trough will follow a parallel trendline determined by the points drawn from the peak of wave 5 to the peak of wave B. The bottom line follows from wave A to C. Sorry for the thick lines, but I think everyone gets the picture. The bottom should be determined by the trendline. Whether today is the bottom, I don’t know.
Going off history relative to BBs, it seems unlikely we would dip much below where we are now. In fact, it doesn't look like we have spent much time at this depth for long at all. A few days or so? Hmmm. I'll be looking for signs that the stock is ending this bear cycle.For tomorrow (11/3) below are some possible price points by closing. First, the BB(20,2) and BB(20,3).
View attachment 257902 View attachment 257901
_____________________________________________________________________________________________________________
Here's the BB(30,3). SP closed today just below the BB(30,3), very atypical. The big question is whether the Model 3 production delay a sufficient catalyst to "shift the mean" of the past trading distribution. If it is, we continue to close below the BB(30,3) range. If not we close right at it or inside of it (similar to the V drop of Feb 2016) and we ride the lower BB(30,3) band down until sentiment reverses. It's also possible we close back closer to the BB(20,2) lower band. I don't think we go down as far as the BB(20,3) band, but who knows.
For reference, here's the BB(30,3) and SP chart going back the last couple of years.
It seems to have overlaid one Elliot wave pattern over the other? Or you can break each big wave into smaller constituents? Not an expert. The underlying pattern seems the same as yours.
It helps sometimes to look more from the distance.
Resistance at 292 $ as most of you know already.
We have been quite some time in the lower band before (3,5 years) and may need a strong flow of positive news to break out above 289$. Last time we had an up move of 119% (177 $ to 389$). A similar move would bring us to $ 650 but I don't call that likely.
Its more realistic I believe to assume a smaller step and brake out already in 2018 once M3 production is ramping up and later the year when predictions about a cash flow positive situations gain ground.
Thank you for your fine analysis. I assume you are referring to the fact that the region around $292 was in the past a resistance level, and it now may serve as a support level. Indeed, levels proven to have been strong resistance in the past, often serve as launching pads for sharp rebounds.
