Other ideas are to sell calls against your long calls to create a call spread, butterfly off your calls (short 2 higher strike calls and buy one higher than that), or just sell a portion of calls for cash and let your current calls run. All of these will give you cash while maintaining some upside potential. When it comes to
options, I've personally found that the best trading strategy for me is anything that puts more cash in my account. When you have cash you have choices. When you don't have cash you are much more limited in what you can do. You may miss out on some gains if all of your cash is not at work but as long as you have cash you can play "the game" and there will always be more trades to make with cash you have.
If you don't like having a chunk of cash (hard to get used to force yourself to follow but I highly recommend it for trading options) then you can put your proceeds into neutral strategies. You can buy calendars or put butterflies with a target strike below where TSLA is trading right now. These will lose if TSLA keeps going up but will make you money if it only goes up a little, stays the same, or goes down. One special type of butterfly strategy called the broken wing butterfly will actually make money if the stock goes up, down, or stays the same and only loses money on a huge run to the wrong direction. The negative of this strategy is the larger margin requirements than other defined risk trades.
Because most people probably haven't heard of the broken wing butterfly here's one example (not recommending it but wanted to give an idea). I chose $340 as the short strike beause Option Sniper said we will revist $341 in February. You can shift the strikes around to suit yourself, the key to the broken wing butterfly is to take in a credit on order entry. In this case, you would go Long 1 February $290 and 1 $355 puts and short 2 $240 puts. Putting on this spread gives you $236 up front. If TSLA keeps going up you keep that money until the spread expires or you close it out. You can not lose money on this spread if TSLA keeps going up. If TSLA goes down you will initially be red on the trade but as the date gets closer to expiration theta decay will occur and you will lose less and less until you are green on the spread. During the last week or 2 you will start to get very green! At this point you will be able to close out the trade for a credit! That's right, this is a trade that you can
put on for a credit AND take off for a credit if you can pull it off. The only way you lose money on this trade is if TSLA ends below $322.64 third week of February. If TSLA expires between $330 and $350 you will do very well on this trade, though I wouldn't wait until expiration. I would take if off when you are happy with the level of profit you are at with it. The great thing about a strategy like this is you can use it to offset some losses on your calls if TSLA doesn't keep going up. If you bought ATM or OTM puts to hedge with and TSLA keeps going up or stays the same you lose 100% of that money. The negative of the broken wing butterfly is if TSLA really goes down you will lose a lot more than you could have made whereas puts could make you several times your investment (but rarely do). If you go out to March or April for your broken wing butterfly you can make the green triangle a lot wider and easier to hit or it will give you a lot more profit for the same strikes but in exchange you will have to wait a lot longer for theta decay to occur so I usually don't go more than 45 days out for these, at most 60 days. This is not an instant gratification trade like TSLA shooting up while you're holding long calls. There are tradeoffs with every strategy and no perfect obvious way to do anything...
