TuneIn problem- MSNBC
Pdadoc
18
Boston
I’m signed into TuneIn, and for the most part it works. I can stream our NPR station, CNN, etc... but although I did get MSNBC to play previously, lately it simply won’t play at all. I see the little “play” icon jump rapidly between play and pause, but it never loads and plays.... am I missing something? Thanks-
Hank101
Go Tigers!
Apr 19, 2016
233
92
Greenville, SC
Correct.
For some reason, several stations can only be accessed from the news section on the main channel menu. And then, you may need to touch the channel selection multiple times, several seconds appart to load. Can't explain why, but seems to work.
Once you tune in, you can then favorite it, and it will work until you restart the car after prolonged stop/power off, after which the favorite appears to loose it's "link" to the original.... So it seems.
shawngregory
Arlington, Texas
I have the same problem with CNBC. To fix it I bring up the TuneIn menu, select a different channel, then try selecting the CNBC again. Sometimes it takes a couple times of going back and forth to finally get it to load.
HookBill
641
655
The OC, CA
This is exactly how I do it for MSNBC. Frustrating, but at least it eventually connects.
