Hello,
I'm debating doing the MCU1 to MCU2 upgrade. I realize FM (& AM/XFM) goes away with the update. A lot of people say you can get (most) FM channels that are local to you on TuneIn
So, I did a bit of testing.
What I found out is, if I add a local FM station on TuneIn (make it a Favorite), it is also added to the Radio FM side. And, vice-versa. If I add it on the Radio FM side, it also shows up in TuneIn.
So, my question is for those of you that have already done the MCU1 to MCU2 upgrade, are you able to find most/all of your favorite local FM stations on TuneIn after the Radio FM feature is removed? Like the FM stations you used to listen to pre-Tesla.
It sorta looks like (to me) that Radio FM & TuneIn are tied together (when I add a station in one, it shows up in the other, and when I delete a station in one, it gets removed from the other).
Thanks!
Thanks!
