Turn radius
Discussion in 'Model S: Driving Dynamics' started by smilepak, Jul 11, 2015.
  1. smilepak
    smilepak Active Member
    Eastvale, CA
    What's ppl thought the u turn radius? The loaner P85+ I am driving doesn't seem to be as good as the Lexus GS I'm used to.
  2. jerry33
    Texas
    There's no doubt it's not as small as the 2001 Prius (9.4 m), but in almost all cases I can make a U turn without additional maneuvering.
  3. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    It's pretty large, but I have had no problems.
  4. BoerumHill
    BoerumHill Member
    New York, NY
    Curb to curb turning radius is 37'. For reference, Prius is 34'2".
  5. smilepak
    Eastvale, CA
    True it's a bit longer than GS
  6. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Car has the largest turn radius of any car I've previously owned, and is my only real disappointment with the car.
  7. mwulff
    mwulff Member
    Danmark
    It turns like your average aircraft carrier. But the ride is awesome;)
  8. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I think the S turning radius is quite reasonable for such a big car.
  9. Tamar
    Tamar Member
    St. Paul, MN
    It's much tighter than our 2008 Mazda6 (which is quite a bit smaller).
  10. bears
    bears Member
    Vancouver, BC
    It's not as tight as my Lexus IS... I have the D, and in general I feel that it turns with slight understeer. Still the best car ever though :)
  11. AnOutsider
    AnOutsider S532 # XS27
    I'm curious if it is improved on the D models?At the Model X unveil, the turning radius of an AWD car with independent wheels was touted. Same should be true of the S, no?
  12. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    And the P has the insane launch like the catapult.:rolleyes:
  13. steph280
    steph280 Member
    Orange, CA
    You guys are all comparing cars of smaller size. Prius? Lexus? Mazda? You need to compare it to Mercedes S class, Lexus LS400, and cars of similar sizes.
  14. mspohr
    mspohr Active Member
    Mercedes S turn radius 12m (39 ft 4 in)
    Tesla S 37 ft
  15. kuttakamina
    kuttakamina Member
    DC
    I find Tesla's turn radius to be similar to what you'd expect of such a car.
    Its got a big turn radius, but thats not something to complain about.
    You want a huge turn radius, try a ferrari. Even making left hand turns from a relatively narrow lane in that car is a chore.
  16. jerry33
    Texas
    That would be the 2004+ Prius, 2001-2003 had a smaller turning radius
  17. electricBear
    electricBear Member
    Doylestown,PA
    37' is the turning DIAMETER. I have two W211 Mercedes E500s. One RWD, the other AWD. My 85D turning circle appears to slot in closer to the AWD. I need to swing a little wider to make the 180 turn into the parking space I use at work vs. what I needed with the RWD, about the same as the AWD when I would take it. One of the reasons the 85D was an easy decision.
  18. Joules Verne
    Joules Verne Member
    Boston, MA
    My BMW 5 series has a 39.4 ft turning radius, so the model s is tighter than that at 37'.
    similar size cars.
  19. RDoc
    RDoc S85D
    Boston North Shore
    I still think they should have a differential braking mode where the inside wheel brakes were applied differentially to tighten up very low speed turns.
  20. jerry33
    Texas
    Given the complaints about tire wear, I suspect that's the last thing they would want to do.
