Turning car Systems on with passenger present, no driver
Damiano
56
0
Los Angeles
It happens to me quite often that I get out of the car to run a short errand and my wife stays in the car. I leave her the key, but unless she opens a door slightly, she has no way of turning on the center console to listen to music or adjust the air. Are we missing something? Is there a way for a passenger to use the car's systems when the driver isn't present? I don't think this is an unusual situation to accommodate in the software, if any v6.2 programmers are present....
Raven
295
19
US
Tap the main screen.
TES-E
412
55
Casa Grande, AZ
Raven is correct. Touch the main screen as soon as you leave the car and it will keep everything on. It only lasts something like 10 minutes (someone correct me if that's wrong). Tap again to get another 10. The other option is to use the phone app to turn on the climate system. This way it lasts 30 minutes.
DDotJ
742
1,127
But remember that after you walk away with the key, the car will lock itself and the touching of the screen will not turn vehicle systems back on. Then if she were to open the door, the car alarm will go off. Also, if she wants to exit the vehicle, she has to unlock the car from the touch screen or the car alarm will go off (she can't just pull at the handle). The alternative is to leave the keys in the car and the vehicle will not lock in the first place.
patn
77
2
Midwest
Are you sure about this? I have left my family in the car many times and walked away with the key but they were able to keep the A/C running by touching the screen. Maybe touching the screen delays locking the car?
I'd like to see an explicit "family in the car" mode that locks the doors but keeps climate control on... something that can be triggered by the driver as he/she exits.
mibaro2
959
Georgetown, ON
Another way to keep the systems running is to put the car in park using the centre console (in the emergency brake area).
Then the driver can exit the car and everything will stay running.
I use this all the time when I hop out for a quick errand.
patn
77
2
Midwest
Interesting - does the car lock when you walk away?
Damiano
56
0
Los Angeles
Thanks all for the pointers. The "touch the screen" method didn't work, but I have a feeling she hasn't tried it for several firmware iterations, so we'll need to try it again on v6.1.
mibaro2
959
Georgetown, ON
@patn : I'll have to check. I haven't used it yet when walking away with the key.
Normally I leave the key with my wife since she is in the car and she wants either a/c on or music. (She can lock it from the control panel if I leave her the key and she wants it locked).
4SUPER9
2,428
1,434
I remember reading in another thread that this was the method to use. I thought though, that we are supposed to put the car into Neutral first. Is that correct?
DDotJ
742
1,127
What I meant was that if they don't touch the screen before the car locks, they won't be able to start up the vehicle systems. Once it locks after you walk away with the key, touching the screen will do nothing
JohnQ
1,612
75
Redding, CT
The confusion on the process and the relative complexity just cries out for an accessories mode...and cracking the door is not the same :tongue:
Brass Guy
1,141
933
Holbrook, MA
The passenger can press on the driver's seat as the door is closed. It only takes a little pressure. My son used to do this when I first got the car.
ken830
Model S 85, Model 3 Performance
Jun 19, 2012
1,108
362
San Carlos, CA
Why didn't this work? If you left the key with her as you exit and close the driver door, the screen will turn off. She then only needs to touch the screen to wake it back up. This has always worked since the general release of the car back in 2012.
Another method is to "unlock" the car with the phone app. Then you don't even have to leave the key behind.
RDoc
S85D
Aug 24, 2012
2,719
1,567
Boston North Shore
This seems to be to be another example of a UI design issue Tesla should fix. The case we just ran into was stopping on a trip and I got back to the car before my wife, who was driving at the time. I had to keep the door ajar to access the front screen. Touching the screen had no effect, the door had to be ajar.
What is the point to this? If the car is occupied at all, why not keep the screen on to control A/C, media, do trip planning, surf the web, etc., and what does keeping the door open have to do with anything?
Zarwin
600
656
Hillsborough, NC
I know not a solution, but my method... if you get out of the car and then stick your foot back in and press the brake lightly, the car will stay on and you can fully close the drivers door and lock the car with all systems still running. It will time out and shut off after 30 minutes I think.
deonb
4,057
4,208
Redmond, WA
In the good old days when there was still a way to communicate from owner -> ownership -> engineering, the ownership team checked for me and engineering was busy working on a mode called the "Keep the doggies alive" mode that they were about to release. This would allow you to set up A/C settings etc. with timeouts & restrictions before you leave the car.
That was 2 years and 4 months ago, so any day now...
travwill
1,335
480
Chicago, IL
Agree, this is what Tesla told me to do in the scenario. Engage the park break in the console and driver can leave, car stays on fully for passenger, and doesn't complain about the key leaving.
-T
brianman
Burrito Founder
Nov 10, 2011
17,515
2,980
Can you follow-up won this with your contact? Maybe a little nudging will help.
