Turning off lights in Park?
Discussion in 'Model S: User Interface' started by vvanders, Jun 12, 2015.
  1. vvanders
    vvanders Member
    Portland, Or
    I've noticed in Park that the headlights, DRL and brake lights all stay on. Is there any easy way to turn the car "Off" without exiting the driver's seat? We regularly park and stay in the car for a while and I would rather they not stay on.
  2. ahm
    ahm Member
    When I need to do that I turn them off via the control panel.
  3. vvanders
    vvanders Member
    Portland, Or
    Yeah, unfortunately that still leaves the brake light on if the headlights were on.
  4. spottyq
    spottyq Member
    Belgium
    Cars in different markets have different abilities, at least regarding the ability to turn off DRL's and such.
    If I remember correctly, Bjorn talks about it in his video about the 'camper mode'. Check it out, the answer you are looking for is probably there.
  5. mknox
    mknox Well-Known Member
    Toronto, ON
    In Canada, DRLs are mandatory, so there is no way to over-ride, but I did discover this: if I'm in the car in Park, and manually switch to Parking Lights, then to Off, all of the exterior lights will go out. As soon as I move the gear selector out of Park, the DRLs will come back on, or if it's dark, the full lighting system.
  6. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Per above, "camper mode" should do the trick.
  7. invisik
    invisik Supporting Member
    Minneapolis
    I read on here before... open the driver's door and lift your butt up off the seat for a few seconds (so it thinks you've exited the car) and then the car will say it's off, then close the door and sit back down. Works great. (well, annoying you have to do it in the first place)
    -m
  8. mknox
    Toronto, ON
    "Camper Mode", if I recall, requires that the car be put in Neutral before setting the parking brake, but in Canada, the DRLs come on and stay on in any gear other than Park.
  9. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Brake lights on in Park; without a foot on the brake pedal? How is that even possible?
  10. mknox
    Toronto, ON
    I think he meant the "tail lights".
  11. Kalud
    Kalud Active Member
    Montreal, QC
    If only we could at least get the lights off when parking brake is on, in neutral... That would do the trick. Unfortunately like you said, anything else than park gets the DRL on...
  12. smilepak
    smilepak Active Member
    Eastvale, CA
    Camper mode keep the DRL on....
    I haven't seen it turned off.
  13. dieselol
    dieselol Member
    Los Angeles
    Even after getting out to plug in at the supercharger and getting back in the car and shutting the door, my headlights will not turn off (let alone DRL) until they hit some magical time-out.
    I've tried switching off the headlights from the controls menu and even powering off the car. They still refuse to turn off until some internal timer counts down.
  14. invisik
    Minneapolis
    Ahh gotcha. There is a setting for that, if it's what I think it is. Go into Controls, then Settings, then Vehicle. An option in the middle of the screen called "Headlights after Exit"--make sure that's off. Post back if that helps or not.....
    Thanks!
    -m
