Turning off the Media/Audio??
StephRob
209
3
Kentfield CA
Is there a quick way to just turn off the audio system? Like an off button? It seems like it is always on and the only way to get it from playing is to turn the sound all the way down. But then it seems if you are listening to slacker, for example, it keeps on communicating with slacker. Or if listening to FM, it keeps telling me what's playing on the station I don't want to hear anymore. It's also a pain to turn the volume all the way down then have to turn it back to your desired listening volume. I'd rather just have an off button and then have all the displays say "Media Off".
Sorry if this is a dumb question and I've just missed something very basic!
Doug_G
Lead Moderator
Apr 2, 2010
17,878
3,339
Ottawa, Canada
Or just turn the volume down to 0
That's how I do it on my Roadster's JVC and it is quite irritating... if you turn off the unit the GPS/rear view goes away. To lower the volume all the way down you have to hold the button, and if you hit a bump your finger jiggles you have to release and start over again.
StephRob
209
3
Kentfield CA
The volume down to 0 is kind of annoying because it takes a while to get there and then you have to find your volume level again when you're ready to listen again. Would much prefer an off button or at least a mute button. Will try the single click of the left scroll wheel.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
Pressing the left scroll wheel turns the entertainment system on and off, regardless of what you're listening to and exactly as you're requesting. (Sorry if my earlier post read as if you should scroll it).
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
198
This is how it works in all of our cars as well. PRESSING the same button you use to change volume usually mutes/pauses/whatever is appropriate.
wycolo
3,068
422
WA & WY
Roadster - day one - rip off face of Radio Unit and chuck into glove box. Problem solved.
Model S - wow, no noise, static, or voices coming at you in stereo. Lasted 2000 miles. Then one morning: dead 17in screen, dead car. Remembered that reboot required holding down both thumbwheels and/or the switch above the t-wheels. Somehow managed to do a couple of speedo reboots and (I guess) a screen reboot as it finally popped on and car became normal once again.
But problem is now the radio is back ON, harassing at every opportunity. If I get lucky with one of the scroll wheels the symbol SPKR-X clogs the right side of speedo, but that *does* restore silence. Next reboot will bring it all back again. Is there a RADIO fuse that is separate from AUDIO (usb) fuse??
> What, from your perspective, is the difference? [ToddBurch]
Because the local oscillator mixes in my brain to ill effect. I_want_radio_dead!!
brianman
Burrito Founder
Nov 10, 2011
17,515
2,980
@wycolo - Can you elaborate on what the issue is with the Model S radio? Thanks. I tried to glean it from your post but failed.
wycolo
3,068
422
WA & WY
Gleaning metaphysics?? Like trying to enjoy a football game thru a spyglass. But I digress.
Seeking the Model S equivalent to: Roadster (rip off radio faceplate). But no effect on: Model S audio(usb).
IOW, no more dj voices coming from out of nowhere all of a sudden just 'cause you started tapping (to the music in your own mind) on the steering wheel. Or npr blather or advertising sound effects or (insert your own bugaboo here). Sure, it could still bring up audio selection from usb stick, but at least that would be your own stuff that you had plugged in.
Conference @ TM: "We need to decide exactly how the operator of the Model S will initiate reboots of the speedo and also of the 17in screen. Do we place tiny recessed red buttons somewhere on the speedo panel and somewhere near the 17in screen for this specific purpose, or what?" Hand goes up: "Why not just use the buttons & thumbwheels that Mercedes ships with the steering wheel?" Another hand: "Sure, sounds good to me." Leader: "Ok, its been a long morning, time for lunch!"
brianman
Burrito Founder
Nov 10, 2011
17,515
2,980
Still not getting the issue with the radio. I guess I need a translator or more caffeine.
jerry33
Mar 8, 2012
19,560
21,910
Texas
But everyone knows you're supposed to tap your right foot to the music. Helps with pulse and glide too.
loganss
Spaceman
Mar 6, 2011
525
39
Maryland
You could also use the media shortcut button and select Bluetooth. If you don't have a device paired it will be silent and even if a device is paired it will only play audio when the device is playing.
XrstalLens
Model S P1327 VIN P01867
Dec 30, 2011
115
0
Kirkland, WA
Getting past all the metaphysics, I think the issue is this: Tune to a radio station, especially an HD one. Click the left wheel to mute. The blue X shows on the dash (if you have it showing media) but the song and artist information continue to update. So, this would indicate the radio isn't really "off", it's just muted. I think this is what the OP is pointing out.
I don't think there's really a way to turn the media center "off", but you could do any of the following things that at least wouldn't show continuous updates (you need to mute it or turn down the volume first for all of these):
* Tune to a non-HD radio station
* Tune to an HD radio station but turn off HD
* Connect a bluetooth device, select it, and don't play anything from it
* Plug in a USB drive, select a song, and then pause it
* Select something from Tune-In or Slacker and pause it
* Probably other ways too.
