Any information in the car manual? I have found none yet.
From some other posts you made, it appears you have a model S that is one of the legacy models. Here is the information in the manual on powering off, and a link to the online manual:
Learn how to power up your vehicle, resolve power up issues, and power off your vehicle.
www.tesla.com
Powering Off
When you finish driving, shift into Park by pressing the button on the end of the drive stalk. When you leave Model S with the key fob, it powers off automatically, turning off the instrument panel and touchscreen.
Model S also powers off automatically after being in Park for 30 minutes, even if you are sitting in the driver’s seat.
Although usually not needed, you can power off Model S while sitting in the driver’s seat, provided the vehicle is not moving. Touch Controls > Safety > Power Off. Model S automatically powers back on again if you press the brake pedal or touch the touchscreen.
Note
Model S automatically shifts into Park whenever it determines that you are exiting the vehicle (for example, the driver's seat belt is unbuckled and the vehicle is almost at a standstill). If you shift into Neutral, Model S shifts into Park when you open the door to exit. To keep Model S in Neutral, see
Instructions for Transporters.
Power Cycling the Vehicle
You can power cycle Model Sif it demonstrates unusual behavior or displays a nondescript alert.
Note
If the touchscreen is unresponsive or demonstrates unusual behavior, reboot it before you power cycle the vehicle (see
Restarting the Touchscreen).
- Shift into Park.
- On the touchscreen, touch Controls > Safety > Power Off.
- Wait for at least two minutes without interacting with the vehicle. Do not open the doors, touch the brake pedal, touch the touchscreen, etc.
- After two minutes, press the brake pedal or open the door to wake the vehicle.
