When I picked up my old car after having service done, or when I get in a rental, the AC is always set as cold as it will go with the fan on high, like that's going to cool it down faster. People have a misunderstanding that they are affecting the temperature of the air being blown.
Yup. Just like the people who set their oven to the max setting to preheat faster.
Well, for a BBQ grill this actually can be true. It could also be true for a gas oven or electric oven, depending on the design ... it is designed to hit a set point and stay there, with little to no overshoot. If you are okay with overshoot, and just want to get to “at least X degrees” as quick as possible (because you are freezing your buns off) then you want the heating elements on max. Who is to say the Tesla HVAC system doesn’t control the temperature of the heating elements, especially for heat where it’s not ‘free’ waste heat, why waste electricity sending more current than necessary through the heating elements than necessary? But if you put it on HI, the heaters will get max current. The air temperature flowing through the vents will actually get warmer.
The HVAC system on the Model 3 may also do something similar for cooling. It’s not the exact same design as in a typical ICE vehicle.
If you want your water to get to a simmer faster, should you set it to the final simmer setting, say 5/10, or should you set it to 10/10 and then back it off once it reaches the simmer?
You are assuming a constant heat or cooling output, but that’s not necessarily how the Tesla HVAC system works.
Comparing to a home thermostat, where the thermal mass in the house is massive, and heat changes are relatively slow compared to within a car where you can change 20 degrees within minutes, is not a good comparison.
In a home, leave the thermostat where you want it. In an EV, if it’s freezing, and if you want comfort as soon as possible, turn it beyond where you want it, then dial it down once it reaches a comfortable temp.
The same can be said for ICE ... setting the “temp” is likely mixing different ratios of fresh vs hot waste-heat carrying air, so if you want to heat the cabin as quickly as possible you set it to max temp.
Just like if you have a bathtub half full of luke warm water and you want to heat it up, you max the water being added to scalding hot, not to ‘warm’ and wait longer to warm up the entire tub.
