Twice car has put itself into Park.
Discussion in 'Model S: Driving Dynamics' started by hemants, Jan 4, 2015.
  1. hemants
    hemants Member
    toronto
    Am I hitting the button by mistake? Don't think so. Twice in a parking lot after coming to a stop my Model S has ended up in park.
    Could it be or am I going nuts?
  2. bluefuego
    bluefuego Member
    St. Louis, MO
    Are you lifting your weight off of the driver's seat? If so, it will shift into park automatically thinking that you have exited the vehicle.
  3. hemants
    hemants Member
    toronto
    Could be, lifted butt up to take wallet out of back pocket. Thanks!
  4. woof
    woof Model X 75D Blue. Model 3 LR Red.
    Make sure you have your seat belt buckled.
  5. Zarwin
    Zarwin Member
    Hillsborough, NC
    Besides lifting off the seat, if you open the driver's door while the car is in drive, and then try to creep forward, it may slam into park as some sort of safety feature. Mine has done this a couple of times when I opened the door to check space alignment and then tried to ease into the space. Scared the crap out of me...
  6. bluefuego
    bluefuego Member
    St. Louis, MO
    This is the same exact scenario as happened to my husband while in a fast food drive through. Went to get wallet to pay; his weight shift was enough for the sensor to say ok, you must have exited the vehicle. Confusing at first.
  7. swegman
    swegman Active Member
    Sometimes when I park the car and get out, I decide I am too far from the front curb and should move up. I'll get back in the car and move it forward with the door open and with the seat belt off. The car does not shift into park. Rather, it flashes on the display in front of the steering wheel that the driver's door is open, and the car chimes.
  8. mknox
    mknox Well-Known Member
    Toronto, ON
    Interesting... I do that the odd time and have not had that happen. All I get is a warning message on the dash about "proceeding with caution" and the constant dual beep tone.
  9. Zarwin
    Zarwin Member
    Hillsborough, NC
    Ok, I may actually be running into the same lifting off the seat issue and the shifting into park has nothing to do with the door being open. It has only happened while the door is open, but now that I think of it, perhaps I'm leaning out a little to see my alignment in the space and lifting up off the seat. Will have to try it next time I get in the car.
  10. stevej119
    stevej119 Member
    Northern California
    ...or maybe in the open door scenario it only shifts the car into park if it was in drive with the door closed and then the door was opened. Perhaps if you get into the car, leave the door open, and shift into "D" it does allow you to pull forward with warning indicator and chimes. but if you're already seated with door closed and in drive you can't then open the door without the car shifting into park. This would make sense as the car is "thinking" that you're exiting when you open the door so it shifts into park. Or, as others have speculated, perhaps it's entirely the result of lifting off the seat. That happened to me as I lifted off the seat to reach for change a few days ago. It's easy enough to test, anyway.
  11. mknox
    Toronto, ON
    I think the key is whether your seat belt is on or off. I've opened my door to peer out while backing up (i.e. car was already in gear) and did not have it go into Park. But I did keep my seat belt on. I get the dual beep alarm and the warning message about "proceeding with caution" but that's it.
  12. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    Hmm that's a good insight. I'll try it with seatbelt on and lifting butt.
    One time I was in the car wash and leaned over to get something in the back seat and the car shifted into park!
    quite scary as the pushing roller forced its way under the tire, lifting the car. I hastily put it back into neutral and luckily there wasn't another car right behind.
  13. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    Yep,
    If seatbelt is off and you're in reverse, trying to back up with the door open will cause a shift to park (lest you rip the doors off with the garage door column of other obstruction).
  14. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Mine didn't used to do this, but started around 6.0 or so. I find it kind of annoying. It's hard to get the car in my garage spot, and my parking sensors malfunction constantly, so sometimes it helps to check alignment with the door open. I'm slowly pulling in and BAM, it slams itself into park. :-/
