Reply to @Rancher: I am going to be polite, but this stuff doesn’t deserve it.
Quote: “Oh, I'm sure it's completely doable with just the one station - if you crawl along along at 25 miles under the speed limit (55 mph). […]being a road hazard because you are so slow compared to the rest of traffic that you are practically a standing object, in order to complete the trip, leaves a slightly sour taste.”
This is the fallacy called a false dichotomy. You are saying that there are only two possible speeds that can be driven: 80+mph or 55mph. What hogwash. You don’t have to go nearly as slow as 55mph to make this easily, and I just did this drive on the 8[SUP]th[/SUP] and 9[SUP]th[/SUP], and the majority of the traffic there goes in the mid 70’s mph. So going about 70 or 72 will be much more efficient and will be very close to the speed of most of the traffic that is going within a few miles per hour of that so that it is not even close to being a hazard or a “standing object”. (Nice ridiculous hyperbole, there, by the way.)
Quote: “, I left Boise with 217 miles of range and got to TF with only 23 left, running right at speed limit of 80 mph […]- just a standard ho-hum trip. Wouldn't have made it to Burley without slowing down. […]And, leaving TF the next morning with a full 255 miles of range, got to Tremonton with 60 miles of range - again, right at the speed limit the whole time. […]Which means that in both cases, leaving with <200 miles rated range means you have to drive under the speed limit.”
And THIS is why people frequently don’t drive at 80+mph. It KILLS efficiency, regardless of whether it’s gas or electric. You used 194 rated miles to go 125 actual miles. That’s burning at 1.5 times rated energy consumption. On that very same stretch from Boise to Twin Falls, I get 1 to 1 on rated miles going about 70 to 72 mph. And then you used 195 rated miles to go 146 actual miles. That’s at 1.3 times rated consumption—again, running pretty hot. Oh, the horror, the tragedy of driving under the speed limit(!!), which is actually, you know, THE LAW. By the way, that is the highest speed limit in the entire country except for a small stretch of one highway in Texas. It’s not going to kill you to go a bit under 80 to drastically help your range. But I know, you’re from Oregon, so you’re excited to taste the forbidden fruit of the 80mph speed limits of Idaho and Utah.
For the rest of that, you are way overestimating those Supercharging times. 60 min, 60 min, 40 min? These are 125 and 145 mile distances, at the most, and the one from SLC to Tremonton at the start is only 76 miles. None of those stops will need to be over a half hour, but of course you want to burn 200 rated miles in 125 real miles, so you want to complain about the charging time to accomplish that feat of wastefulness.
