TxTag/EZpass
Discussion in 'Texas' started by dsm363, Nov 1, 2012.
Tags:
  1. bryanng
    bryanng Member
    Dallas, TX
    So just an update. I had tried putting my tolltag in the black area but it was never recognized. I moved it to the upper left hand corner of my windshield, which is where I had it in my previous car, and lo and behold, it is working and being picked up by every toll gate I have gone through. Haven't tried it at DFW or Love Field, but it's working for now.
    Seems to be a lot of inconsistency as to what works for people but mine never worked in the black area to the right of the camera but is working now in the top left hand corner.
  2. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    Are these issues only occurring at airports?
    I read on another thread that in Texas as long as you have an account with NTTA, they will charge the lower rate just based on reading our rear license plate. And the only issue is at the airport. Can anybody confirm this?
  3. taurusking
    taurusking Member
    East Texas
    NTTA reads mostly my license plate and charges after reading the license plate. No difference in charging vs Toll tag sticker.
    I have no problems with DFW airport but at DAL after using one time my NTTA toll tag account got suspended.
    Called NTTA and had it re-activated and no issues since then.
  4. Chris TX
    Chris TX Active Member
    Dallas, TX
  5. Thundalicious
    Thundalicious Member
    Texas
  6. Chris TX
    Dallas, TX
    No issues. It reads every time on the tollway and airport readers. There's even a little part near the rain sensor that gets hit with a wiper blade, and it's doing fine for ~2 years. The key is to make sure all the bubbles are out using soapy water and a squeegee or credit card. Since you have a newer car, the key is to mount it just left of the VIN window. The wiper blades won't touch it and it's much easier to apply without crawling all over the car ;)
    If you're having a hard time with it and are ever in the West Plano area, I'd be happy to help install it.
  7. gizmoboy
    gizmoboy Member
    Rancho Palos Verdes, CA
    FWIW, I just taped my tollgate over the black patch and went thru DFWE. No problem going in; had to back up a little an re-inch forward to get it to be read on the way out.
    This is a December 2015 build.
    (About to get my windshield replaced due to distortion, so I want to make sure the new one also has this spot on it...)
  8. L.Robinson
    L.Robinson Member
    Dallas, TX
    I'm using the NTTA bar on the front grill and it seems to read sometime and others its by the license plate. Maybe I should look into the outside cover for a tag. My Tesla was built in Nov 2015.
    @gizmoboy - where is the windshield distortion? I have some across the very bottom of the windshield above the hood but the rest of the field is clear.
  9. prasunshah
    prasunshah New Member
    Dallas, TX
    Should I order the normal size one or the small size - I have a Model S and the wife drives a Model 3. I live in the West Plano area and would love to meet you and get your help in applying it
  10. famelec
    famelec Member
    Tyler, TX
    Is it necessary to mount the TX Toll Tag on the outside of the Model 3???
  11. bollar
    bollar Disgruntled Member
    Southlake, TX
    No, it works fine in the normal location by the mirror.
  12. Shaggy
    Shaggy Member
    Austin
    In Austin, they USED to have a test reader at their MoPac office... Otherwise the test seems to be DFW airport. ;-)
  13. BioSehnsucht
    BioSehnsucht Model 3 LR
    DFW, TX
    Now that I have my Model 3's plates, I wanted to go get a TxTag ... but my only options are Model S, X, and Roadster. What the hell, TxTag, get with the times!
    edit: Some googling, apparently I can just edit the page and submit anything I want : TXTag Question - Tesla Model 3 : Austin
    Though I'd rather not do that, in case they get all butthurt about it later.
    Does TxTag work at DFW airport now? It used to be they specifically didn't work with anything but NTTA tags.
  14. jeremysmith214
    Dallas
    You should definitely purchase the vinyl overlay. Great product
  15. L.Robinson
    L.Robinson Member
    Dallas, TX
    Chris TX, is that you selling at ideafab.shop now? What part of West Plano are you in.
  16. Zishan
    Zishan Member
    Houston, TX
    I recently got a TXTAG on my 2016 Model S. It reads perfectly fine to the passenger side of the rear view mirror.
