Typical Range Degradation on M3 LR?
Hello everyone,
I just bought my first Tesla last week. A 2020 Model 3 Long Range with 30k miles. Upon taking delivery, I did my first mistake and stopped by a Supercharger to set the maximum charge to 100% in order to see what range it would estimate on a full charge.
270 miles. I understand that mileage is lost over time and whatnot. But I'll say I was a bit shocked that in 3 years and 30k miles it had lost over 50 miles of range (322 miles new).
So, I was wondering if anyone could shed some light and provide a sanity check for me. Is this average degradation or is it accelerated to an extent?
The range shown st the battery symbol, like this:
That range is not adaptive. Doesn’t matter if you drive like you stole it or like grandma, it will still show the same range for the same energy content.
So a full charge, assuming no degradation/change in capacity will show the same range.
Its really a energy meter, scaled in km or mi.
My car shows 1km for each 152Wh that is remaining in the battery (theres also a 4.5% buffer below 0km).
So if the ”fuel tank” is half, it always shows half of the full range.
Upvote 0
Unless my math is wrong that is 26% capacity loss. Under waranty, you get a new battery if it falls to >30% loss of capacity in 8 years.
Based on what I have read on this board, Tesla doesn’t give you a new battery. They can give you a refurbished one that has range >70% of what your vehicle’s original range was. That’s not nothing but don’t expect a brand new battery if yours meets the warranty criteria for replacement.
Reactions: zoomer0056
Upvote 0
Ah, that is great to know, thank you. I didn't realize that would be static.
I find basic math to be the best real world mileage reading. :) Simple enough to take the total mileage I've driven and divide it by the total kW charged.
So far they indicate a decent amount of more real world mileage. I've charged 65 kWh, and driven 296 miles for an average of 4.55 miles/kWh. I'm happy with that number!
Reactions: AAKEE
Upvote 0
This part is true.
This part is close. The warranty wording is not to just meet 70%. It says they will give you one that has at least the capacity yours had at the time of the failure. So if someone had a car that was degraded only down to 85% of original capacity and failed, they would need to provide one that was about at that 85% level, not just at least 70%.
Reactions: Hiline and AAKEE
Upvote 0
No need to do a full change everyday. As a best practice for longer battery life, limit your charge to 70-80% unless you need the higher charge due to your travel plans. If your daily travel is 50 miles then 60-70% charge is sufficient., You can set that up in your App and the car will only charge to the limit you have set up on a daily basis or occasionally based on your commute schedule. Occasional full charge for travel necessity is OK but should be avoided unless it is necessary.
Reactions: Bobo818
Upvote 0
Thank you!!
Upvote 0
Oh, no!
80% is most probably the worst SOC to use. In some cases worse than 100%.
The baby-by-80% is a myth
This chart shows actual Tesla Model S cells taken out of a 6 months old model S.
In this case, 80% was worse than 100%.
This is Panasonic 18650 NCA cells, as close as you get without doing like above:
We can see that 80% is worse than 100%, this time also.
This is 2170 NCA cells of a non disclosed brand:
As there are not very many 2170 brands with NCA chemistry, it is a good chance the actually used panasonic 2170.
I bought 35 pieces of Panasonic 2170 and from my tests, I did get redults very similar to the second from above research graph.
There are a lot more research reports testing Panasonic NCA cells, closely related to the cells Tesla use.
This one do not show that 80% worse than 100%. On the other hand, 80% and 100% is more or less as bad (or good if you like).
We can see that staying at 55% or lower is reducing the calendar aging by half.
Shortening the time above 55% to a minimum, or avoiding completely will reduce the degradation rate to half.
Thank you!!
First of all, if you follow the Tesla advice to charge below 90% (thats 50-89%) for daily driving the battery will be fine.
But it will not have the lowest degradation.
I suggest you follow this advice if you like to reduce the degradation:
-Charge often
-Do not charge more than needed until next charge (which is soon as per the above statement).
-Charge late. Calendar aging is the dominant degradation factor and shortening the time at high SOC will reduce degradation.
The lower the SOC, down to 0% SOC, the less degradation. The largest single win is by having the battery on the lower side of 55%. (This statement means - low SOC is really good - 80% is not really good)
Low SOC, below 20% or below 10%, is good. It is not bad for the battery at all - that’s a myth.
100% SOC is not as bad for the battery as the forum myth says. You do not need to drive asap as the degradation is about the same as at 80%. But as there is no reason to have the car parked long time at 100%, you should not leave it like that. You should not leave it at 80% either as it is about as ”bad” as 100%.
This is my M3P after 2 1/2 years, 64.000 km (like 40K mi). The blue line = my car
Green= the average other M3P that use teslafi.
I use 55% as the daily charging level.
I charge every day.
I charge late, somthe charge is finished shortly before the drive.
My car has used really low SOC a lot.
Usually parked at work for one week at the time with about 7-20%.
Upvote 0
Oh, no!
-Charge often
I charge every day.
Thank you this is really helpful as I plan to have my car for many years!
Reactions: AAKEE
Upvote 0
Oh, no!
-Charge often
I charge every day.
Just curious, can you expand the odometer range for comparison vehicles? Your sample size of 8 is quite small.
Also, I think your approach can be summarized as: keep the car at as low SoC for as long as possible.
Reactions: AAKEE
Upvote 0
