Tyre Pressure on the Sunny Side
Discussion in 'The UK and Ireland' started by Rob R, May 29, 2020.
  1. Rob R
    Rob R Member
    Dundee, Scotland
    My Model 3 is the first car I have had with tyre pressure monitoring. I am sitting in the sun at the moment, and the tyres in the sun are sitting 2psi higher than the shaded tyres. Is this a normal thing? Is 2psi reasonable? Pretty sure the pressures are the same sat in the garage.
  2. Andrew_SE23
    Andrew_SE23 Member
    London
    Yes. Also, next time you are going for a moderately long drive, see how the pressures increase as the air inside the tyre heats up from tyre friction.
  3. Electric Dream
    Electric Dream Pilots the Millennium Milkfloat
    UK
    In the current weather you'll probably find your pressures will increase 4-5 PSI from 'cold' after a drive. They should then equalise (assuming you're not just doing laps around a roundabout).
    If they are still at different pressures after that, you need to check the cold pressures with an accurate gauge.
  4. Durzel
    Durzel Active Member
    Bath, UK
    Bit embarassing.. where are the tyre pressure indications on the display? Are they accurate?
  5. Roy W.
    Roy W. Battery running low...
    Derby, UK
    Swipe left on the bottom box in the status window. Or right, I can’t remember without checking :D
  6. kevuwk
    kevuwk Member
    UK
    They are on the right so swipe left if you want to include both directions
  7. Electric Dream
    UK
    If you set them to PSI they will show whole numbers i.e. 42, 43 etc. so any fractions are rounded up or down. The sensors are reasonably accurate, but I've compared the displayed pressures against a proper motorsport gauge and they can be 1-2 PSI different to actual, which isn;t really anything to get to concerned about on the road. As long as they're within 1 PSI of each other when cold you'll be OK.
