romad
Also, just to confirm I won't have to stop at any weigh stations or stay off any certain roads?
No, here are the rules and trailers aren't listed. Weigh Stations
Since the X height is 15.5 inches and the U-Haul trailer is 18 inch - the offset should be ~2.5 inches. Is that fine?
I can't see the attached photo. Do you recommend the hitch you previously linked in this scenario or something else? Since the X height is 15.5 inches and the U-Haul trailer is 18 inch - the offset should be ~2.5 inches. Is that fine?
The photo shows me using the exact same hitch I linked. I've used it to tow a variety of trailers; without any issues including a U-haul trailer. 99% of the time, it's my go to hitch. (Note, just realized this wasn't mentioned yet; you'll also need a hitch pin!) It's light, easy, reliable, and fits within specs. I definitely recommend it.
If you're looking to spend a little more, I also have a 3/4" rise hitch (claimed, it's actually 1") I bought it because it seemed to fit within specs (it doesn't) and came in a case that made it neat and easy to carry. I pair it with a weigh-safe 2" hitch ball with a 2 5/8" adapter for when I'm towing larger loads/trailers. While it's taller, I don't typically prefer this hitch setup as it's quite a bit heavier than the one I recommended above.
But here's the link as well.
https://www.amazon.com/gp/product/B016QJZNCS/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Yea this one seems to be sold out as well. I will purchase the other one you linked. Thanks
Is this hitch pin fine? 1/2 in. x 3-3/4 in. Hitch Pin with Clip
Or this one from Amazon: https://amzn.to/2MhVCdv ?
@KirkNason, your photo didn't come through. You may have to use the "Upload an Image/File" button below the post window to attach your file. if dragging isn't working.
It may be easier to move to Germany than schedule a service center replacement...@ohmman How I got this for my US Tesla Model X is beyond me...
Thank you for the quick response.
Setup a mobil service request to fix it.
