UI Tweak #2 -- AP Stalk
ForeverFree
638
1,446
Sherman Oaks, CA
Going from four stalks to two was an improvement. Using the gear selector for AP was a master stroke; there's virtually never a time when one must use shifter and AP.
However, inability to adjust speed via stalk is a big step backward. And, using upward movement to turn off AP can lead to inadvertent shifts into neutral. (It's happened to me twice ... despite being hyper-alert to the possibility.)
Fix is simple.
Keep existing right-hand stalk.
However, use the same underlying switchgear as left-hand stalk (which allows both vertical and horizontal movement).
Adopt same AP stalk mode as Models S and X:
Horizontal to trigger/stop AP (one flap out = TACC, two flaps = AP, push in = off)
Vertical to adjust speed (first notch = 1 mph/kph, full movement = nearest 5)
Hardware cost should be minimal. Retrofit labor (for existing < 10K cars) should not be excessive.
Solves adjustment gripe.
Solves inadvertent shift gripe.
Makes transitioning S/X <---> 3 much simpler and more consistent.
I think just have the first one (horizontal stalk activate/deactivate AP) would be a huge improvement. I really don't see it happening though as I don't think they want to do any hardware swap, unless people start to have accidents because they accidentally switch to N and didn't know a 2nd down will put it back to D. I was actually practicing this on my MX yesterday. Driving on local street, put it in N, first down trigger a "ding" warning and does nothing, 2nd down put back to D. You know someday I may decide to order a M3... :D
Hardware part should be minimal. Keep same stalk. Use existing switchgear part from other side. Tweak software.
